What 7.2v battery pack do you use?
Hi everybody,
I am looking to use a 7.2v battery pack to run the BOE and was wondering what brand/company do you guys use/like for your projects/RC? I know the mAh I am looking for will be around 1900-2000. That will be an increase of 700 to 800 from the generic battery I am using now. Also what do you recommend between NiCd and NiMH? Thanks guys and girls.
Matt
Matt
I would look at a NiMH for greater power to weight ratio, and the fact that you do not have battery memory issues like you do with NiCd...
The NiMH packs used for RC hobbies are a good place to start, AND there are several online sites that make custom packs for a very reasonable price.
Bob
You might also check your local stores for clearance pricing on their old 3000mah pack, I picked a bunch of these up cheap not so long ago!
www.towerhobbies.com
Make sure to click to the third page of batteries that are listed.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
Post Edited (Dave Andreae (Parallax)) : 8/16/2006 6:31:59 PM GMT
Matt
However, if you are just looking for better runtimes on your BOE, you can stick with lower performance batteries. The $25 GP 3300mah 7.2 pack at radioshack is a great deal. I probably wouldn't go any lower (in price or mah) than that. You may also want to consider www.cheapbatterypacks.com/main.asp?sid=602686&pgid=superlisting&type=car&manufacturer=4&model=23, the elite 4300mah 7.2volt pack is $36 without the upgrade (again, the upgrade will only help if you need it). They can also custom make a pack to fit your needs.
Lipo's offer better power to weight ratio than Nimh's, which is why they are growing popular with RC, but the performance gain probably isn't noticeable or worth it for your BOE. They also pose more of a fire hazard risk than Nimh's (just look at dell).
Keep in mind with any of these batteries you should use a quality peak charger to properly charge these Nimh batteries. Overcharging can damage these batteries more severely than they could Nicd's. I would suggest this charger: www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLD5&P=ML since it displays all the charge info, and costs only about $20 more than the least expensive peak charger out there.
Bulkhead,
Thank you for questions and suggestions. My BOE is going to be mounted on a 1:10 scale RC car chassis. At the moment I am in the midst of redesigning an ESC to be powered through the 3-pin servo connector and also have a servo to control steering. That will be my platform that I will be using for the next couple of months to a year to test out numerous things; i.e. wireless communication, camera, sensors, and maybe a GPS. So I am trying to figure if one 7.2v battery that is around 3000-4000mAh will be enough to power all of this or maybe 2 2000-3000mAh battery. One for the platform and one for everything else.
Matt
-Matt
I second the 3300's...unless you can get your hands on liions (I use 3.6V 1100mAh liions to make packs...they're lighter)...though I used to use the 3300's from RS...they're a very good deal. The 4300's arent worth it in my opinion; almost double the price for an extra 1Ah? no thanks, Ill just buy a second pack and swap out when one dies.
Just out of curiousity- what car are you using?
I was thinking of upgrading the motor down the road once the weight began to add up. I hope I can get more then 20 minutes of run time out of this. I don’t plan on driving the platform around at top speed. I still haven’t figured out what speed I want it to move yet. So I might be looking at 35-40 minutes per charge. If not then I might have to figure out some other type of power source.
Then the 3300’s seem to be the pack I will be buying. Here is a link to the same car that I bought.
-Matt
hmmm. I do not like the sound of that. I don't want to be following this thing around replacing its batteries every 10 minutes. Does anybody have any suggestions or ideas to fix this problem. I might have to start a new thread on this.
-Matt
Again, given your application I would say it shouldn't be uncommon for you to get 3 or 4 times the runtime of a regularly driven RC car. Given the nature of the project, I doubt you will run it faster than 5mph or so. Most RC cars go at least 25mph, at that speed the battery is drained much faster than at 5mph, given road friction and air resitance (which increases exponentially). Also, many RC cars are driven offroad, which adds even more of a load to the motor, not an issue for you.
If you really want to be scientific about it, hook up a multimeter to your car when you get it and measure the current peak when you accelerate from a stop to a walking pace (or whatever you think will be your top speed). Take the peak current reading, and as your worst case scenario, calculate your runtimes with a 3.3Ah pack as if that peak current reading were the continuous current draw.
