index out of bound when printing — Parallax Forums
ChetChet Posts: 150
edited 2006-10-09 17:40 in General Discussion
Gents, it is the first time I am using version SX-KeyEditor-3.2R3lg to continue work on a program for my Valentine 1 detector.
The error message is " index out of bounds (0)" when I tried to print the listing
Any ideas?
Chet
  • ChetChet Posts: 150
    edited 2006-08-16 00:24
    The actual message is "list index out of bounds(0)"
    Regards
    Chet
  • BeanBean Posts: 8,129
    edited 2006-08-16 00:25
    Chet,
    I get the same error. I have notified the developer and I assume he is working on the problem.
    Bean.
    Cheap 4-digit LED display with driver IC·www.hc4led.com
    "You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
    edited 2006-08-16 00:38
    Thanks Bean.
    Regards
    Chet
  • PJMontyPJMonty Posts: 983
    edited 2006-08-17 00:09
    I'm looking into the list index out of bounds message. It's inside a VCL that I didn't write, so it's more of a pain to figure out why it's not working.
    PeterM
  • SteveDSteveD Posts: 64
    edited 2006-10-05 03:34
    I am experiencing this problem, so I was wondering if the “fix” is out there and I just missed it or is someone still working on it?
    Thank you,
    Steve
    edited 2006-10-05 03:42
    Well, one fix is to open your SX progams from Notepad and use its print utility. At least that's what I've been doing.
  • YendorYendor Posts: 288
    edited 2006-10-05 04:08
    Unrelated, for a great programming text editor I recommend (Highly) ultraedit32.
    You can even integrate a compiler into it!
    www.ultraedit.com
    Don't worry Peter, we still need you!
    Rodney
    There is a new version of the IDE available which fixes the printing problem. You can get it here:
    www.parallax.com/sx/downloads.asp
    There might be a little confusion since the the previous IDE on the page was 3.2r3, and the new one is 3.2.3. The "r3" in the previous case had to do with the installer itself. Trust me. If you have a printing problem, get the new IDE that is version 3.2.3.
      Thanks, PeterM
