re PLP_A Pull up not working as it should — Parallax Forums
OzStampOzStamp Posts: 377
edited 2006-08-16 01:26 in General Discussion
Has anybody experienced an issue with the PLP_A not working properly.
I have 4 inputs we want to read in on Port A and have used PLP_A = %0000
Now when checking it with a HI-Z Fluke Multimeter it tells me the pins float...
and my code does really strange things ( obviously seeing floating pins ..hi and lo's ....)
As soon as I connect resistors to the pins as pull ups ( some 4.7K even 10K type)
my code behaves as it should...
Cheers
  • BeanBean Posts: 8,129
    edited 2006-08-15 14:50
    Please post your code. There is very little we can do without seeing the code, the whole code, and nothing but the code (that causes the problem).
    Bean.
    Cheap 4-digit LED display with driver IC·www.hc4led.com
    "You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
  • pjvpjv Posts: 1,903
    edited 2006-08-15 18:37
    Hi OzStamp;
    If what you wrote is literally as your code reads, then you are might be missing the "#" literal prefix in the pull up definition.
    But in any case, I fully agree with Bean; without being able to see it, we can only guess what your code is doing, and that's not a good use of our time.
    Cheers,
    Peter (pjv)
  • OzStampOzStamp Posts: 377
    edited 2006-08-15 22:19
    Hi Guys (Thanks for your concern)
    I have attached my code for your perusal.Tried to add the # it is not valid code the compiler rejects it
    As mentioned before my program behaves as it should but the Pull up resistor command does not work
    I have external Pull UPS at the moment and I like to get rid of them.
    Cheers
    Ronald Nollet Australia
    edited 2006-08-15 23:20
    Ronald,
    The pull-ups work fine with nothing connected to the RA pins. What do you have connected to them ?
    The pull-ups are very weak (approx 20K) so any circuit connected to them might bring the level down.
    BTW: You know you can just use "adder = 15 - RA" instead of all them IF statements...
    Bean.
    Post Edited (Bean (Hitt Consulting)) : 8/15/2006 11:23:45 PM GMT
    edited 2006-08-15 23:34
    Hi Bean.
    I converted a BS2E program from a customer quickly so code looks accordingly.
    (All done free of charge basically to get a sale)
    Thanks for the pointer re code I tried something similar but had problems ..( as we are talking about)
    So just adjusted the customers code to suit ..
    (Omron A6C type 6 pinner device dip top adjust BCD output)
    A little BCD dipswitch as above is connected to the pins A0...A3 pulling these pins low.
    Or nothing at all just connecting very short jumper wire to the VSS IDC female socket to the right of them..
    So no other stuff at all.
    Using the SX Tech board to Proto-type it ( with the SXKEY F)
    The application is very price sensitive and the PCB needs to be small
    Parallax OZ disty
    Ronald Nollet
    edited 2006-08-16 00:15
    Hmm, I see no reason a BCD switch wouldn't work with the internal pull-ups.
    If you pull the BCD switch out of the circuit, then do the pins go high ?
    Bean.
    Yep Bean it is Hmm here also.
    With nothing connected to the pins and all pulled up on a anti static mat grounded using the Debug mode
    now I can pins toggling all by themselves on port RA and also RC .
    Tried another chip same thing exactly the same ...
    As soon as I put my pull up resistors back in all runs as it should.
    In debug mode there seems to be a pattern as to when it happens.
    As to exactly when I have no idea but when it sits in the "final do nothing loop" the pins all read 1
    So this is as it should be.
    Cheers
