I/O from Hyperterm vs Debug window.
I am writing a couple of embedded apps that need occasional user interaction via a serial connection.
From a development point of view the Debug window is ideal, but the end user is only going to have access to Hyperterm - or similar.
Formatting the output to look OK in either isn't a problem, but input is another issue...
I can read chars from the Debug window using DEBUGIN and SERIALIN, but from Hyperterm I am getting nothing
Port settings are the same in Debug as Hyperterm (9600,8,N,1, no flow)
Any 'idiot gotchas' I should be looking out for ?
Many thanks
Spag
Many thanks
Spag
In fact, I tried to get it sending so I could give you a better idea of the settings, and it just sort of hung there.
So, if you're interested in something else, you can try a program called Terminal by Br@y++, which you can find via Google.
