Looking for sample code of visual C++
hi,
·· does parallax provide sample code of visual C++·for servo controller- USB to control·the servo motors.
Jiunn Siong
Jiunn Siong
·· We do not provide any sample source code for any language other than those used by our controllers.· However on any PC language the procedure is the same.· You need only open the COM Port assigned to the device by the USB Driver (Use like a standard COM Port) and send serial commands just as outlined in the following documentation.· I hope this helps.· Take care.
http://www.parallax.com/dl/docs/prod/motors/ServoController.pdf
csavage@parallax.com
· do I need any driver to be installed to PC as to open the COM Port assigned to the device by the USB Driver.
Jiunn Siong
