Comparing Bytes Anywhere in RAM
I wrote a subroutine to compare bytes in two arrays. The intent of the comparison is to compare the bytes at each location until there is no match. If Idx reaches zero, then all of the bytes matched.
In stepping through this DO loop, I found that the comparison for the first byte always fails even when the data at the two locations described by the SX/B are the same (as verified by reviewing the locations in RAM on the debugger screen).
When I reviewed the assembly, it appears that it retrieves the value for the specified byte in TimeDate correctly. Before retrieving the value of the specified byte in MyDate, it assigns FSR to $10. In my program, the two arrays are not located in the $10 memory bank. When the code after the FSR assignment executes, it looks like it retrieves values from the $10 bank and the comparison fails.
I have also tried using
with the same results. Any ideas?
Joe
Idx=7
DO UNTIL TimeDate(Idx)<>MyDate(Idx)
DEC Idx
IF Idx=0 THEN EXIT
LOOP
__DO_4: ; DO UNTIL TimeDate(Idx)<>MyDate(Idx)
MOV W,#TimeDate
ADD W,Idx
MOV FSR,W
MOV __PARAM1,IND
MOV FSR,#$10
MOV W,#MyDate
ADD W,Idx
MOV FSR,W
MOV __PARAM2,IND
MOV FSR,#$10
CJNE __PARAM1,__PARAM2,@__LOOP_4
MyDateIndex=MyDate DO UNTIL TimeDate(Idx)<>__RAM(MyDateIndex)
Joe
Are your arrays defined as Byte (8) ?
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Since my program is made up of 14 SXB files, I'd rather attempt to faithfully reproduce the code in a single file showing the error rather than have someone trace the 14 files (this is why you see the large array and the declaration of many byte variables in the SX/B code below). In so doing, I think I resolved the error which raised more of a guidelines question for me.
The assembly code below demonstrates the error. In the SX/B, I populate some memory and then copy that memory using MoveBytes (you may recognize this from a previous post). Then, I call CompareBytes.
When the processor enters into the CompareBytes subroutine, FSR is set for the memory location of TimeDate and MyDate. This causes the processor to assign the wrong place in memory the value of Idx (MOV Idx,#6).
In setting up for the initial compare (TimeDate(Idx)<>MyDate(Idx)), the code assigns __PARAM1 the correct value from TimeDate (__PARAM1 has the correct value because FSR did not change during the retrieval of the TimeDate value) and then assigns FSR the value of $10.
When the code attempts to assign __PARAM2 from MyDate, the value is incorrect because the location of Idx is not the same as when it entered the subroutine (i.e., the value of FSR has changed).
;inside CompareBytes MOV Idx,#6 __DO_1: ; DO UNTIL TimeDate(Idx)<>MyDate(Idx) MOV W,#TimeDate ADD W,Idx MOV FSR,W MOV __PARAM1,IND MOV FSR,#$10 MOV W,#MyDate ADD W,Idx MOV FSR,W MOV __PARAM2,INDTo correct this, I added
to the end of MoveBytes (see below). The DO loop in CompareBytes executes correctly after the change to MoveBytes.
I reviewed some other assembly code around my program, and there is a pattern indicating that after every use of FSR for indirection, it is assigned $10.
Would this be a general guideline in working with SX/B?
This reproduces the error.
DEVICE SX48,OSCHS1 FREQ 50000000 CompareBytes SUB 1 MoveBytes SUB 3 PROGRAM Start BigArray VAR BYTE(48) TimeDate VAR BYTE(8) MyDate VAR BYTE(8) AByte1 VAR BYTE AByte2 VAR BYTE AByte3 VAR BYTE AByte4 VAR BYTE AByte5 VAR BYTE AByte6 VAR BYTE AByte7 VAR BYTE AByte8 VAR BYTE AByte9 VAR BYTE ABytea VAR BYTE AByteb VAR BYTE ABytec VAR BYTE Idx VAR BYTE Start: PUT TimeDate, $00, $11, $15, $13, $08, $07, $06, 0 MoveBytes TimeDate,MyDate,7 CompareBytes MyDate END CompareBytes: Idx=6 DO UNTIL TimeDate(Idx)<>MyDate(Idx) DEC Idx IF Idx=5 THEN DEC Idx ENDIF IF Idx=0 THEN EXIT LOOP RETURN MoveBytes: ASM :Again: MOV W,__PARAM1 MOV FSR,W MOV W,IND MOV __PARAM4,W MOV W,__PARAM2 MOV FSR,W MOV W,__PARAM4 MOV IND,W INC __PARAM1 INC __PARAM2 DJNZ __PARAM3, :Again ;MOV FSR,#$10 ;remove the semi-colon to correct the error ENDASM RETURNJoe
Yes but only for the SX48.
It's better to use the SX/B command "BANK" with no parameters. This will set FSR correctly for the SX28 or SX48.
Bean.
