Robotic Mower
With the power of our wonderful search tool - I have seen some people talk about robotic lawn mowers.... Has anyone actually done this? I am really interested if you have. I want to make one....
I want to control the blad with an electric motor though. I know that will use up batteries quick, but that is what I want to do..... Use tank treads and a motor on each side for driving. Can do something like the Z-Axis on my mill for rasing and lowering the chassis for cutting height.
If anyone has made one, I would like to hear about it.
- Stephen
As for the electric mowers - we used them when I lived in the UK. Not seen them much here in the US though. Figure once I understand the motor controllers for DC motors and then try stepper motors. Then get an idea of torque required and power.
Then take it from there. I have a CNC mill and a lathe that is not CNC. Once I get the transformer to power them. A lot of what I need for mounting brachets and adaptors I can make. Within the next month or so, I should have my transformers. (Need more funds for purchase).
There was a previous post about a robotic lawn mower where I posted data on the mower for sale from Northern Tool.
http://www.northerntool.com/webapp/wcs/stores/servlet/CatDsp?No=42&storeId=6970&N=143
Automatically cuts lawn with push of a button
Also has manual mode
Cutting system features 3 battery-powered 150 Watt electric motors with 3 blades
Delivers a 21in. cutting width
Equivalent to a 5.5 HP gas mower
5800 RPM blade speed (twice the speed of a gas mower)
6 mowing height adjustments at front, 2 adjustments at rear
Cuts lawn in criss-cross pattern to eliminate lawn stripes
Triple chamber mulching system eliminates bagging of clippings
Safe, quiet and environmentally friendly
Uses perimeter wire system to define mowing area (requires simple one-time setup)
Sensitive bumpers redirect mower away from trees, rocks and any obstacles
Lift Sensor stops blades immediately when mower is lifted
Child Guard prevents children from operating mower
Perimiter switch prevents operation of mower if switch is off
3 hours average work time
Suitable for lawns up to 10,800 sq. ft.
Cuts approx. 5400 sq. ft. per charge
Plug into included charger after mowing
Knobby wheels work on high grass, slopes and bumps
LCD display panel and audio user interface with intuitive and easy to use menus
Includes 24V battery pack
Approx. 20 hours charging time
Durable polyethylene shell
Mower is 35in.L x 26in.W x 12 1/2in.H
Model RL-850
2-year limited warranty
I am also building one as are seval other members. I think that you have to look at the project in 3 stages, being :-
1) Moving platform - chassis, wheels, motors, bumpers etc
··· This will need to be able to potter around and bump and navigate round contacted obsticles.
2) Safety & Containment
··· This is the difficult part. You need to design and build safety devices to stop the blades in the event the bot is picked up or turned over (mercury switch on main power), stop theft (when power turned on - keypad to enter code), how do you keep the mower on the lawn ? (buried wire fence - using either hall effect or RF down a burried wire) - this is diffucult bit.
3) Fit cutting motor & blades. mount motor vertically in round compression collar which will allow you to alter the height.
I am at stage 2 at the moment, even though i have ideas on 3. i have a bot that will bounce round a room ot lawn with obsticles but it falls of the edge of the lawn. i have looked at the Lego line follower and various buried wire fences, the idea being the bot measures the amplitude of the RF as it nears the wire then as it passes it starts reducing, so it reverses. this seeme to be the sticking point for most lawn mowers and myself and Molle are working on the problem. So if you or anyone can help with the Buried wire Fence problem it would be great.
In theory I figured out how I will do most of this. Now have to do it.
I want to use treads like a tank. Anyone with siggestions on what to use as the treads and wheels to drive them? Trying to keep it as cheap as possible. Thanks
www.rctankcombat.com/articles/track-systems/
That link has some great info. I am going to try the bike chain idea. Going to hardware store to get some supplies. Now need to figure out how I will hook my motors up to it to drive it once this part is finished.
Been doing a lot of searches on google and came up with a lot of ideas. To start I could leave the blade being gas powered then convert it to electric later. Not sure what I will do right off on that part. Thanks again.
If the system fails the blades must stop. All systems must contribute to the continued rotation of the blade so that if any one fails the blade does as well. the other danger is that using a gas powered cutting system meeens that the blades will be very chunky and therefore the rotational energy that they store will mean that they could continue to rotate after power is cut.
Sorry to sound like a kill joy but i do believe that the first systems should be safety orientated. if it cant be done safely then dont do it.
I would also suggest that you consider a simple solid state switch instead of anything liquid. Liquid can get bounced pretty good and in the even something gets turned on its side or rolls... Or just buy a dual axis accelorameter
But what is a solid state vice a liquid state switch?
Thanks -
Let us know what you go with.
www.solarbotics.com
Look under gears and tracks on the right side.
- Stephen
Just trying to "Think out of the box" and offer some input...Hope it's constructive for you...
Quik
