Need to get a string back
I have put together various code from some demos trying to learn a few basics. I can Tx a byte on pin 2 and Rx on Pin 0 and pass the byte back for display no problem, thanks to Mikes advice on an earlier post. I cannot solve for a string however. I enclosed the code if someone could take a quick glance and point me in the right direction.
I have sent a string term.str(string("led")) and want to get it back for display on the tv.
A definition of "string" would help also, as well as a definition of "terminating the string with $0D" I did attempt to add the character $0D to the end of "LED" using the chart under help, but it would not add it. Therefore I don't know how to terminate "LED".
Note: This code will send the string, but it will not pass it back as I was trying to do.
Post Edited (originator99) : 8/13/2006 5:18:02 AM GMT
I don't see term.str(string("led")) in your program. I do however see ser.str(string("led")).
I added term.str(string("led")) right underneath ser.str(string("led")) and was able to see
led just fine on my TV monitor.
When you use the string modifier,....
term.[b]str[/b]([b]string[/b]("led"))...it is equivalent to using the DAT descriptor and putting the information there. See below...
...In the case of using the string descriptor, the "termination character" of $00 is automatically added.
$0D is not the termination character, but instead the "return key" character.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 8/13/2006 5:31:52 AM GMT
Thanks for the additional info.
You have to decide what passes for a terminator (usually a return). Something like this might work:
PRI receiveStr(address,count) | c repeat count c := ser.rx if c == $0D byte[noparse][[/noparse]address] := 0 return byte[noparse][[/noparse]address++] := cYou call this with "receiveStr(@array,20)" assuming array is a 20 byte area. If no more than count-1 characters are used in the array, the string is zero terminated when a return is received. The return is discarded.
...Notice the added line TextData[noparse][[/noparse]2] := $44. Adding this will replace the lower case d
with an uppercase D in the displayed TV output of leD.
In a similar situations...
l would correspond to TextData[noparse][[/noparse]0]
e would correspond to TextData[noparse][[/noparse]1]
d would correspond to TextData[noparse][[/noparse]2]
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 8/13/2006 6:04:40 AM GMT
Here is the revised code with what I think Mike is suggesting, although I am unclear as to if he really meant to use the literal code: PRI receiveStr(address,count)
These lines seem to be causing a hickup as the program never gets past this when I call it. I am getting the concept a little clearer.
Notes are in the new file.
I believe this section of code is working properly.... When I add the line c := %11001001
effectively bypassing whatever ser.rx is doing, Array0 to Array3 all show the bit pattern.
I do not see a hiccup or program halt on this end do to this section of code.
[b]PRI[/b] receiveStr(address,count) | c '***address is a real ram address?**** [color=#990000]<-- This is correct[/color] [b]repeat[/b] count c := ser.rx c := %11001001 [b]if[/b] c == $0D [b]byte[/b][noparse][[/noparse]address] := 0 [b]return[/b] [b]byte[/b][noparse][[/noparse]address++] := c▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
Maybe I am making this more complicated that need be anyway. The goal is this::
1. Send a string containing the propellers unique address(ip address possibly w max address capacity = 1000) to another propeller acting as an intermediary, which will in turn gathers from its group info and relays the info as required to a third location(master), logging and responding with a PC application.
2. Send a follow-up string with several data bits to indicate some sensors states.
For example:
%00000000 string contains the following info possibilities:
databit 0 = sensor 1 state 1 or 0
databit 2 = sensor 2 state 1 or 0
databit 3 = sensor 3 state 1 or 0
databit 4 = some info state 1 or 0
databit 5 = some info state 1 or 0
databit 6 = unused
databit 7 = unused
databit 8 = alarm
so that %00000001 means sensor 1 is high and requires attention or logging from the master controller,
So that is what I am looking to accomplish withthe FullDuplexSerial object.... Send strings at a timed interval to show ACTIVE(avoid polling), plus show any sensors high as needed to call attention. My thoughts were to start out simple like what I posted with the serialtest code, then incorporate the sub level receivers, then move on the master. I see it as using 1 propeller sub level hub that talks to maybe 12 to 24 other propellers, then it serially talks to the Master to give a run down of the 12 - 24 that it is monitoring, for example,
sub level prop to master>
some string that says
address1 just had this sensor high
address2 just had this state high
address3 just had this state high
The master in turn sends a string back to the appropiate prop needing attenion and that prop acts accordingly. The Rx string may include a new passcode to be used by a cardkey attached to the prop. This cardkey serial number can be changed on a some basis by the master, magnetically entered onto the card, and the prop checks for the serial number as the card is entered. The master can revoke access by sending the prop a null serial number for the reader. Hotel door concept.
All that ramble aside, is the path I am on with the early stages of code the way to go about this? My thoughts are, the prop 1 of 1000 receives a string into a buffer, I then need to get that info into a tangible and usable form, and act on it.
From your description of what you want to do, it sounds like you want to encode some bit information into the bytes of serial data. That's a nice way to pack information to minimize how much is transmitted and to simplify unpacking on the receive side. If you ever need to use more than one byte of information, you may need to uniquely identify the first byte (in case there's an error and the master and slave processors have to re-synchronize). Alternatively, you could limit the number of bits of information to 6 and add 64 to every value to make your data into printable characters. Then you can use the control characters like return and the punctuation characters as delimiters.
Sometimes, fixed length sequences are used (2 bytes, 3 bytes, etc.) with the first byte being a zero value or all one bits, then the remaining bytes follow (with none of them being all zero or all ones). Look at some of the Stamp AppMods or the IRBuddy for examples of serial devices that allow arbitrary binary values in their control sequences.
Post Edited (Mike Green) : 8/13/2006 2:29:48 PM GMT
Thanks a whole lot fellas, I am off to figure how to make a byte from several bits. Maybe something like addition will work.
FinalByte := Sensor1+Sensor2+Sensor3
00000000 + 00000100 + 00100000 = 00100100
ser.tx(FinalByte)
This works in reverse to extract your original sensor info back into bits:
first add your individual bytes before Tx:
sensor1 := 00000001
sensor2 := 00000100
sensor3 := 10000000
finalbyte = sensor1 + sensor2 + sensor3
ser.tx(finalbyte)
ser.rx to get the byte back in
display received byte term.bin(finalybyte,8) = 10000101
then to extract individual bits back out:
sensor1 = (finalbyte - sensor2) - sensor3 = 00000001
Pretty simple.
It seems if you send a byte only, you have to ser.rx for a byte only, you can't do receiveStr and expect to get the byte you sent, it give a solid white screen. But if you send a byte and then a string, you can do both.
How cool is this TV object? Especially since my only LCD died. Replacement here on Monday. It works in its demo mode, but thats it.
You need a set of bit masks like:
Then to extract the values and test for them:
When variables Sensor1 := %00000001 and Sensor2 := %00000010 and Sensor3 := %00000100, I get a return value and can display it on the screen. BUT, If I change various simulated sensor states, the return may happen or not, if it does return, all the values are shown correctly, but some cases nothing returns and there is a blank screen.
For example,
Sensor1 := %00000000
Sensor2 := %00000000
Sensor3 := %00000000
Will return a blank screen
but this always works.
I don't know if you've given up on the receiveStr routine or just figured out that you don't need it. Remember, it's written to accept the specified number of characters and only stops early if one of the input characters is $0D which it stores as a zero byte (to get a zero-terminated string).
Post Edited (Mike Green) : 8/13/2006 11:55:29 PM GMT
When I set all sensor variables to %00000000, and receive back the finalbyte and compare it using:
if (recbyte & Sensor1Con) == Sensor1Con
Then of course recbyte & Sensor1Con are NOT equal, sense I sent sensor1 out as %00000000, therefore the IF statement does nothing in effect without a further implied THEN to follow? Which is why I was putting the implied THEN statement "sensor1 := %00000001" after the IF, to make the variable become %00000001 if the recbyte & sensor1con resulted in %00000001. If the result was not equal, the sensor1 should automatically remain at 0 be default.
That being said, with the correction, there is still a solid screen when all values are sent out as 0. When I bring a debug line down to see how far it is getting, it actually gets to the IF statements, but the subsequent lines to display the sensor values are ignored for some reason. My guess is that either the ser.rx is seeing all 0's, and doesnt bother, or the IF statements are tripping me up since they don't have anywhere to go IF false.
I didn't really give up on receiveStr, as I was focussing on learning how to create a single compacted byte and extract it on Rx. Since I wasn't dealing with a string in this case, I didn't think I needed it.
I am much closer now to the understanding. Whats nice is, this lesson applies to many other uses in the future.
if (recbyte & Sensor1Con) == Sensor1Con term.out("+") else term.out("-") if (recbyte & Sensor2Con) == Sensor2Con term.out("+") else term.out("-") if (recbyte & Sensor3Con) == Sensor3Con term.out("+") else term.out("-")This will display 3 characters with a "+" if the sensor is true and a "-" if it is false. For test purposes, you can make a series of test values that you send out the serial port and listen for the echo like:
repeat x from 0 to 5 ser.tx(testSamples[noparse][[/noparse]x]) ... recbyte := ser.rx ... DAT testSamples byte %00000101,%00000110,.....This works as desired to set the sensor back to its original state.
Thanks Mike!
if (recbyte & Sensor1con) == Sensor1Con
else
sensor1 := %00000000
if (recbyte & Sensor2con) == Sensor2Con
sensor2 := %00000010
else
sensor2 := %00000000
if (recbyte & Sensor3con) == Sensor3Con
sensor3 := %00000100
else
sensor3 := %00000000
