BS2 v Propeller
I started a discussion in the robotics forum under Finite State Machines and·am· now looking at using a propeller chip instead of a BS2.
If there is any feed back on the pluses or minuses of the BS2 v the Propeller I am all ears. At this point I can go either way.
I'm biased towards the Propeller. Most new ICs now are 3.3V or can work with 3.3V signals. The serial input/output is fully buffered and full duplex so you won't miss a character if your program is busy doing something else. The same thing's true of
most other I/O in that they're handled independently (by other COGs on the chip). You can write your own multiprocessing routines in SPIN and you can mix SPIN and assembly (with some restrictions due to the way the chip works).
Program memory: BS2px - 8x2KBytes . . . . | Prop - 32KBytes
MPU Cores. . . . . : BS2px - 1 . . . . . . . . . . .| Prop - 8 syncronizable COG's / shared rescources
MPU speed . . . . .: BS2px - 32MHz Turbo . . .| Prop - Internal RC/External crystal/freq-in DC to 80MHz compile/runtime config
Instructions/sec . : BS2px - ~19,000 . . . . . .| Prop - ~ 20,000,000 (or so i've read in other threads, i think this is a calculated #)
Proccessing . . . . : BS2px - serial . . . . . . . . | Prop - parallel
I/O lines . . . . : BS2px - 16 + 2 dedicated . . | Prop - 32 (after final program first loaded to EEPROM, 2 I/O's for I2C EEPROM - recomened)
Features - BS2px : Not very familiar with this version, i believe it has a 128 byte "scratch pad ram" and I2C innstructions built in
Features - Propeller : Global 32KB ram, per COG or internal proccessor (8) (included video generator, 2 specialized I/O assistants for freq synth ADC opp PWM & more!, 2KB local ram, I/O register, I/O direction register, separate PLLnX tap capability), true 32bit parallel proccessing @ up to 80MHz, a 100% parallax product!, and more i'm sure i forgot.
Despite that it's a 3.3V device this is about it's only shortcomming that i can think of vs ANY Basic Stamp! Spin, as i'm finding out, requires an open mind for a fresh concept of programming. The concept, comming from a stamp P.O.V., is more diffucult than the language.
I've come across rumors that the prop was overclocked to crazy speeds stable @ up to 100MHz & barely stable around 160+MHz region, lol talk about critical mass!
Definetly a E3 (Electronics Engineer Extrodinare!)
"I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
Post Edited (RinksCustoms) : 8/13/2006 5:13:42 AM GMT
The Stamp is way simpler and easier for a beginner, but with experience and with help from a few external circuits and a penchant for minimalist thinking you can take it far.
The Prop can run circles around the Stamp, as seen in the spec sheet advantage,but it also has power enough to daunt the beginner or anyone on the first rungs of the its particular learning curve .
Tracy Allen
www.emesystems.com
It is reality,·todays electronics needs to run faster and consume less power.
If anything, I will say the 5v devices·are old relics of the past.·
Are there projects and/or books·to help the learning curve or is it assumed that a certain level of knowledge exists?
or a download of the same at www.parallax.com/dl/docs/prod/prop/WebPM-v1.01.pdf
What would I need to get started with a Prop?
Does Parallax have a kit that contains the chip, board·and a book? I didn't see any when I checked but could have been in the wrong place.
The choice you make depends partly on what you want to do with it. If you mostly want to experiment with the Propeller and see what it can do, you might get the Demo Board and Manual. The Demo Board has Video and VGA outputs and PS/2 keyboard and mouse inputs. It also has a microphone and a stereo headphone output. There's a small breadboard with 8 Propeller I/O pins accessable nearby. If you want to develop an application with the Propeller, I'd suggest the Wulfden board since it doesn't commit any of the I/O pins, yet you can easily add the parts for a PS/2 keyboard and video output. The parts are just the connectors and a few resistors, nothing fancy.
Post Edited (Mike Green) : 8/14/2006 3:36:03 AM GMT
Given that each leg will need 3 servos (1 for each joint and one for travel) and each gripper will need 5 servos (1 for the elbow, one for the base, one for the wrist, one to turn the wrist and one to grip) this gives an immediate need of·28 useable items not including moving the broom.
I could go with a simple wheeled robot and reduce things down significantly, but then run into problems like going up and down the step for the living room.
Post Edited (AIman) : 8/14/2006 7:53:28 PM GMT
If you don't want to use a second Propeller, consider a pair of Parallax Serial Servo Controllers at $39 each. They can handle up to 32 servos total (16 each).
Considering what you're going to spend on all that hardware, you might as well get 2 Propellers.
Post Edited (Mike Green) : 8/14/2006 9:27:46 PM GMT
