Moving Bytes
JDOhio
I have a few places in code where I move bytes around like this:
Since I have a few places, I would rather have a subroutine to call such as
MoveBytes Here,There, 6
I'm not familiar with a couple things.
1) How might I pass the address of a memory location to a subroutine?
2) Once I am in the subroutine, how might I read one location and place it in another?
3) Did I make this too hard?
This was my attempt:
I'd much rather prefer something like
But I'm not sure how to set up the address indirection.
Joe
FOR Index=0 to 6 There(Index)=Here(Index) NEXT
temp1=4 ASM MOV __PARAM1,#Here & $FF MOV __PARAM2,#Here >> 8 MOV __PARAM3,#There & $FF MOV __PARAM4,#There >> 8 MOV FSR,#__PARAMCNT MOV IND,#4 MOV FSR,#$10 CALL @__MoveBytes ENDASM MoveBytes: temp2=__PARAM1 temp3=__PARAM2 tempA=__PARAM3 tempB=__PARAM4 FOR ACount=0 to temp1 READ temp2+temp3,temp4 ASM MOV FSR,#tempA+tempB MOV IND,temp4 INC tempB ENDASM NEXT RETURN
MOV W,#Here ; There(Index)=Here(Index) ADD W,Index MOV FSR,W MOV __PARAM2,IND MOV FSR,#$10 MOV W,#There ADD W,Index MOV FSR,W MOV IND,__PARAM2
Joe
In SX/B array names are just constants into the virtual __RAM array.
So you can do "tempbyte = __RAM(here)"
or you can assign the variable name to a byte variable and use that as an index into __RAM
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Post Edited (Bean (Hitt Consulting)) : 8/11/2006 2:09:13 AM GMT
John J. Couture
San Diego Miramar College
