Help needed understanding serial com
1. When a byte/word/long is received serially, what are the methods to store the data for future use? If you receive several bytes that are needed for use later, would you first assign a memory space to "offload" each string until further need? If so, is that data retreived via specific ram locations or variable names?
2. Using the fullduplexserial object, there is a method called rxbyte which says it is to ' Receive byte (may wait for byte)".
The method has a local variable called "rxbyte", which I assume is the temporary holder of the most recently received byte. I want to get that byte into my program and use it on an LCD to reflect the value of the byte recieved. I notice there are 2 variables in the fullduplex object(tx_buffer, rxbuffer) that get assigned [noparse][[/noparse]16] memory allocations. I assume these are loaded in sequentially starting at either the top or the bottom first. If that is true, should I be able to access those locations using the rx_buffer(x) variable/memory location?
3. What would need to be adjusted on the object to receive a word or long, or bit for that matter?
Here is what I am doing, pin 1 connected to pin 2. LCD ncrements on Tx, but not Rx. Data are visible on scope. Tx shos up and counts to 256, Rx stays at 0. Can someone please point out the error.
CON
_clkmode = xtal1 + pll16x ' use crystal x 16
_xinfreq = 5_000_000 ' 5 MHz cyrstal (sys clock = 80 MHz)
led = 0
lcd_pin = 0
lcd_baud = 19200
lcd_lines = 2
off = 0
on = 1
VAR
byte counter
byte sentbyte
byte recbyte
obj
ser : "fullduplexserial"
lcd : "debug_lcd"
PUB Start : rxbyte
sentbyte := 0
recbyte := 0
dira := %11011111_11111111_11111111_11111111
outa := %00000000_00000000_00000000_00000000
lcd.start(15, 19200, 2)
lcd.cursor(off)
lcd.backlight(on)
lcd.cls
ser.start(2, 1, 0, 19200)
Repeat
!outa[noparse][[/noparse]0]
waitcnt(800000 + cnt)
ser.bin(sentbyte, 3)
waitcnt(8000000 + cnt)
sentbyte := sentbyte + 1
recbyte := rxbyte '
lcd.gotoxy(0,0)
lcd.cls
lcd.decF(sentbyte,0) 'counts to 255, recycles
ser.rx
lcd.gotoxy(0,1)
lcd.decF(recbyte,0) 'always shows "0" , doesnt change
CON
led = 0
lcd_pin = 0
lcd_baud = 19200
lcd_lines = 2
off = 0
on = 1
VAR
byte counter
byte sentbyte
byte recbyte
obj
lcd : "debug_lcd"
PUB Start : rxbyte
sentbyte := 0
recbyte := 0
lcd.cursor(off)
lcd.backlight(on)
lcd.cls
Repeat
recbyte := rxbyte '
lcd.gotoxy(0,0)
lcd.cls
ser.rx
lcd.gotoxy(0,1)
spin
993B
This would set the variable "myChar" to the received character. You can declare an array of bytes to store a sequence of characters terminated by a return ($0D) like this:
OBJ ser: "FullDuplexSerial" VAR byte myChar[noparse][[/noparse]20] PRI something | i repeat i from 0 to 18 myChar[i] := ser.rx if myChar[i] == $0D myChar[i] := 0 [/i][/i][/i]This also changes the return-terminated string to a zero-terminated string to make it easier to
do other things with the string since all the string manipulation routines in the library and in SPIN
assume a zero-terminated string. Note there's no checking here for input lines longer than 20 chars
or for more than one line in 20 characters.
2) The buffers are internal to the object and are not intended to be accessed from "outside". Just use the documented "methods" like rx and rxcheck or tx.
3) There are already decimal, hexadecimal, and binary "formatters" in the FullDuplexSerial driver for transmitting. If you want to do the same thing for receiving, you may need to write your own routines or modify someone else's. I've attached some routines of mine used to convert characters from a display window. Change "vga.windowChar(...)" to "ser.rx" and it will work with serial input. One routine will scan in a decimal, binary, or hexadecimal number and convert it to a long value at a location you pass to the routine. Another routine will scan in a sequence of non-blank characters (like a name) and store them, 4 per long, at the location(s) you specify
Post Edited (Mike Green) : 8/9/2006 11:17:13 PM GMT
there is an "i" in square brackets after each "myChar" at the bottom
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
1. Don't use i or b as subscripts. (If affects boldface, too.)
2. Replace each [noparse][[/noparse] with [ on each edit of the post.
You can also go to www.phipi.com/format, paste your program there, and click "FORMAT". It will add the necessary HTML goodies for you.
CON
led = 0
lcd_pin = 0
lcd_baud = 19200
lcd_lines = 2
off = 0
on = 1
VAR
byte counter
byte sentbyte
byte recbyte
obj
lcd : "debug_lcd"
PUB Start
sentbyte := 0
recbyte := 0
lcd.cursor(off)
lcd.backlight(on)
lcd.cls
ser.start(2, 1, 0, 200000)
repeat
lcdoutput
PUB lcdoutput
lcd.gotoxy(0,0)
ser.tx(sentbyte)
lcd.gotoxy(0,0)
lcd.cls
lcd.bin(sentbyte,8)
lcd.gotoxy(0,1)
getrx
lcd.bin(recbyte,8)
if recbyte == 255
reportgood
PRI getrx
recbyte :=ser.rx
PUB reportgood
lcd.gotoxy(0,0)
lcd.cls
lcd.str(string("PASSED"))
repeat
The info in your post helped out a lot. I am still looking to understand parts of your comments if you could please point me in a direction for the learning info, particulary:
repeat i from 0 to 28 ' what is this accomplishing?
if mychar == $0D ' what does $0D reperesent
mychar[noparse][[/noparse]20]... an array, but how are the bytes loaded into the array(what order and to what ram location, or does it matter), and how is the info accessed later for use? I assume the array is "one" location or "bank" representing a series of bytes that can be retrieved as a "string", or multiple bytes in order so to speak. How the array is accessed is and use is confusing. Is the [noparse][[/noparse]20] is the obvious limiting factor for the number of bytes that can be stored at one time?
Obviously I need access to some learning tool rather than "trying to sort it out", I am not asking you to take the time to respond point for point.
I have looked all over and can't see excatly what I need to get an understanding and practice with serial communication. I have observed on the scope the basics of sending one byte at a time using your first set of code. It does appear that the Propeller can transmit and receive at the exact same time, although I thought that req'd multiple cogs to accomplish. It also appears that the Rx is always "ready" to receive a byte, and that once you write over that byte with a new byte, that old byte is gone forever, thus requiring some method to store the bytes. How a Long can be sent is puzzling. Broken up into 4 bytes? Or just send the Long as a whole part?
Thanks for helping, I know this is mainly thinkng out loud and rather scattered. No need to take an hour to respond in detail, a link would be great though for the basic concepts. I may have missed it, but I didn't see specifics or a tutorial in the manual similar to your earlier response. I think the best starting point is to decide the content that I want to transmit, whether a byte, word or long, then plan what needs to happen at the receiver with that info. Ultimately I'd like a scheme to transmit from 10 up to 500 Propellers to one main PC terminal for monitoring and logging of several bits of sensor data(PC terminal), plus remote control of any particular Propeller(only several bits required as well of control data + the address of the Prop). This is to be done via either a proprietary fiber optics network or ethernet, with assigned IP's or addressed at each Propeller. This is all local, within hundreds of feet of each other.
