FInalizing a product
ive always wondered....once i breadboard on the microcontroller and finalize a product... how do i duplicate it without having a stamp? i look on alot of RC cars and there is no microcontroller to throw commands out so i was just wondering how they do it?
Also, although the stamp module is often referred to as a microcontroller, only one of the components on the module is the actual microcontroller.
For finalizing your product, you would need to build/create some form of circuit assembly for your desired parts. For instance, you could use a stamp module, an OEM stamp module, or purchase the stamp components for use on a custom circuit board.
Most boards that you see are using components on a board, which is exactly what the stamp modules are.
1. If you're only making one or two of them, you put a BS2 in each one. $50 each, and you're done.
2. If you're making thousands, or millions, of them, you contact Parallax, and design in an "OEM" version of the BS2. This is MUCH less expensive, and I believe they have volume discounts.
3. If that still costs too much, you go the 'native PIC' route (or native SX28 route), and program in PICBasic or SX/Basic. This costs a little more up front for the development system, but is the lowest cost to manufacture.
