1.5 - 3 Volt Motor Control
Hi everyone,
I have a quick question. I need to control to basic 1.5 - 3.0 V motors. I do not need to control the speed as much as the direction. What is the best way to do this. Am I correct by thinking that since the BS2sx outputs 5V, I would need to regulate the voltage to 3V and also increase the current to match the current needed by the motor? Does anyone have a quick and dirty solution to this with using common parts that can be found at Radio Shack?
Thank you in advance!
Ben
Ben
I will post my schematic and such after it is all done.
Thanks!
