Propeller Boe-Bot — Parallax Forums
Propeller Boe-Bot
RegorRegor Posts: 19
edited 2006-08-08 14:39 in Robotics
Any plans for a Boe-Bot kit thats uses the Propeller chip?
  • Russ FergusonRuss Ferguson Posts: 206
    edited 2006-08-08 13:11
    A Propeller Robot Controller board is available if you want to modify an existing BOE-BOT. Have a look at: http://www.wulfden.org/PRC/
    I seem to recall that the holes in the board do not line up with mounting holes on the BOE-Bot chassis but that does not have to be a big problem if you own a drill.
    You can easily use a piece of plastic or printed circuit board cut to fit with holes drilled at the corners and mount the Propeller Demo Board using two layers of double-sided foam tape. Works great! The long double-sided header pins that come with the servo extension cables from Parallax fit nicely in the breadboard.
