Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
ADC returning "0" — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
ADC returning "0"
bulkhead
405
2006-08-07 21:50
edited 2006-08-07 22:34
in
General Discussion
I am using it with an LM324 opamp and a Sharp IR ranger. I had this working before but after redoing the wiring to clean it up, it doesn't work any more. Any ideas on where to check? Thanks.
Peter Verkaik
3,956
2006-08-07 22:00
edited 2006-08-07 22:00
Recheck your new wiring.
Start with the GND and 5V connections.
Then check if the data connections are correct (no swapped pins)
You probably already did that, but as it worked before, it must be in
the new wiring.
regards peter
bulkhead
405
2006-08-07 22:34
Hmm, I tried switching pins and it works, seems like my pin 0 is dead [noparse]:([/noparse] . Maybe I can still use it for something else...
Edit: Just tried pin 0 with my PING sensor, it works great! This is strange...
Post Edited (bulkhead) : 8/7/2006 10:40:42 PM GMT
Sign In
Register
to comment.
the new wiring.
regards peter
