Broadcast mode with TV_TEXT
So, I am left a little confused after trying to gather enough information on how exactly to get the propeller to transmit to a nearby television on channel 4 or 5, etc..· I've tried modifying the stuff as mentioned here http://forums.parallax.com/showthread.php?p=572073·...· I got it to the point where I can hold the propeller about 3 inches from the tv antenna and see a somewhat garbled screen that resembles what I was expecting.· Am I missing something, I had read that hanging just a 6-10" wire would do the trick up to about 10' away.·
Does anyone have a version of the tv_text modified to work in broadcast mode?· Or is anyone willing to point out which amazing oversight has led to my ignorance here?
Thanks...
Post Edited (sharpie) : 8/7/2006 8:52:32 PM GMT
Thanks...
VHF analog channel spacing is 6 MHz. Changing to a 6MHz crystal would probably allow any of the lower channels to work. Even though the Propellor is supposed to work only up to 80MHz, most will work happily at 96MHz with the 6MHz crystal. You have to change your programs to include a new _CLKFREQ declaration.
Post Edited (Mike Green) : 8/7/2006 9:09:38 PM GMT
Thanks for your help.
