ready to cut the umbilical sx-key
Hi folks. I am ready to disconnect my Sx-Key and let my SX ride the 5.125 MHz crystal all by itself in my circuit. Problem is, I don't know exactly how to do this. I have the crystal and inverter (if necessary) on my benchtop and am ready to go. Do I first make the oscillator with the 74AC04 (I don't need any help for this step...) or can I drive the SX with the crystal by itself? Anyhow, if someone could kindly give me a step-by-step I would appreciate it.
Thanks!
Thanks!
It depends how close to 5.125 MHz you need to be. The SX will probably work by just putting the xtal onto the OSC1 and OSC2 pins and using OSCXT1 or OSCXT2 on the device line.
If not, you may need some capacitors on each side of the xtal to ground.
That should be in the area of ±100ppM of 5.125 MHz.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Post Edited (BebopALot) : 8/10/2006 3:43:10 AM GMT
Bean.
Different value caps will offset the crystal frequency.
You would need a calibrated frequency counter to be able to know how much the caps are pulling the frequency.
To calculate it you need all kinds of technical data about the crystal (an the SX too).
You can try finding the smallest and largest cap value that works, then pick a value in the center.
Try different OSCxxx settings on the device line too.
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
if you are putting .1 uf to ground either side of the crystal
you are doomed.
something like 20 pf would be a better choice.
