Power two BOE boards from same power supply?
bulkhead
Can I simply add 2 jumper wires to the breadboards, connecting the Vin and Vss together? Or is connecting it this way different than connecting it through the power jack? If it can be done this way that would be easier than making a "Y" adaptor.
However, do not connect the Vdd from one board to another, I don't think the voltage regulators like to work in parallell...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
NerdMaster
For
Life
