SPI write and then verify is not working for me.
LoopyByteloose
I am trying to Write to a CANbus interface via SPI·with a BS2p24.
The purpose is to intialize its registers for normal operation.
For some unknown ·reason, when I write a value into the device's registers and follow with a read of the same register, I get a different value.· The different value is always consistent unless I change what I am writing.· So I presume that there is a timing problem in the change from SHIFTOUT to SHIFTIN.
Can anyone point out my mistake?
I suspect that I am dropping a clock pulse in some instance.
Some values come back consistently correct and other values come back consistently [noparse][[/noparse]always the same wrong answer] wrong.
I suppose I could test the code on an SPI EEPROM to see if the problem occurs there to verify software, but I would have to reconfigure my breadboard.
' {$STAMP BS2p}
' {$PBASIC 2.5}
'···· MCP2515 Second Test Program - single test
'······ 8/2/2006·· V 0.50
' NOTE- CURRENTLY RETURNING WRONG VALUES.·· /
'· HAVE NO IDEA WHY THIS IS SO.· Maybe Wiring·· /
'···· Author: George Herzog
'···· Purpose: To verify the SPI interface is functional by
'···· Writing and then verifying values to SPECIFIC registers
'···· in the MCP2515
' Pin Assignments
PINcs·· PIN 15······· 'Chip Select Pin
PINdata PIN 14······· 'SPI combined data I/O
PINclk· PIN 13········ 'SPI clock
' SPI command codes
RESET······· CON· $C0
READspi····· CON· $03
WRITEspi···· CON· $02
'· VARIABLES
result···· VAR···· Byte
'TESTREGISTERS
'REGISTER $00
'·· WRITE· Register $00
· LOW PINcs
··· SHIFTOUT PINdata, PINclk, 1, [noparse][[/noparse]WRITEspi]
··· SHIFTOUT PINdata, PINclk, 1, [noparse][[/noparse]$00]
··· SHIFTOUT PINdata, PINclk, 1, [noparse][[/noparse]$0a]··· 'Write $0a
· HIGH PINcs
'·· READ· Register $00
· LOW PINcs
··· SHIFTOUT PINdata, PINclk, 1, [noparse][[/noparse]READspi]
'·· CHANGE from SPI output to input while PINcs remains LOW
··· SHIFTIN PINdata, PINclk, 0, [noparse][[/noparse]result]
· HIGH PINcs
· DEBUG " Reg $00 WROTE $0a >>> TEST VALUE = ",· IHEX2 result, CR······ 'Verify ·$0A
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
' {$STAMP BS2p}
' {$PBASIC 2.5}
' Pin Assignments
' SPI command codes
'· VARIABLES
'TESTREGISTERS
'REGISTER $00
· LOW PINcs
· HIGH PINcs
· LOW PINcs
· HIGH PINcs
···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
Results:
·Reg $00 WROTE $0a >>> TEST VALUE = $0A
CANTX········ PIN 13······················· 'CAN Transmit
CANRX········ PIN 12······················· 'CAN Receive
CANCS········ PIN 11······················· 'CAN Chip Select
CANCLK······· PIN 10······················· 'CAN Clock
CANData····· VAR Byte····
TestCAN:
·· LOW CANcs
··· SHIFTOUT CANTX, CANCLK, 1, [noparse][[/noparse]WRITEspi]···· 'WRITE· Register $00
··· SHIFTOUT CANTX, CANCLK, 1, [noparse][[/noparse]$00]
··· SHIFTOUT CANTX, CANCLK, 1, [noparse][[/noparse]$0a]············ 'Write $0a
·· HIGH CANCS
·· LOW CANCS
··· SHIFTOUT CANTX, CANCLK, 1, [noparse][[/noparse]READspi]
··· SHIFTIN CANRX, CANCLK, 0, [noparse][[/noparse]CANData]······· 'CHANGE from SPI output to input while CANCS remains LOW
·· HIGH CANCS
·· DEBUG " Reg $00 WROTE $0a >>> TEST VALUE = ",· IHEX2 CANData, CR······ 'Verify· $0A
GOTO TestCAN
Try the code with some other values. Like $C0, $AA, and $BD.
If you get consistent results, I may have a bad chip.
I see you went with the separate Input and Output Pins.
The board I am presently using has that darn'd combined I/O with a 4.7K resistor.
It may be inserting a timing delay.
I have my own board coming from the fabricators that is like your set up.
I may have to wait for that in order to have something that functions right.
Can anyone who has seen a similar problem lend advice?
Debug Results:
Reg $00 WROTE $21 >>> TEST VALUE = $21
·Reg $00 WROTE $32 >>> TEST VALUE = $32
·Reg $00 WROTE $D8 >>> TEST VALUE = $D8
·Reg $00 WROTE $06 >>> TEST VALUE = $06
·Reg $00 WROTE $5D >>> TEST VALUE = $5D
·Reg $00 WROTE $F5 >>> TEST VALUE = $F5
·Reg $00 WROTE $8F >>> TEST VALUE = $8F
·Reg $00 WROTE $15 >>> TEST VALUE = $15
·Reg $00 WROTE $B7 >>> TEST VALUE = $B7
·Reg $00 WROTE $2B >>> TEST VALUE = $2B
·Reg $00 WROTE $D4 >>> TEST VALUE = $D4
·Reg $00 WROTE $BD >>> TEST VALUE = $BD
·Reg $00 WROTE $CD >>> TEST VALUE = $CD
·Reg $00 WROTE $B1 >>> TEST VALUE = $B1
·Reg $00 WROTE $76 >>> TEST VALUE = $76
·Reg $00 WROTE $21 >>> TEST VALUE = $21
· char = 100
TestCAN:
·· RANDOM char
·· LOW CANcs
··· SHIFTOUT CANTX, CANCLK, MSBFIRST, [noparse][[/noparse]WRITEspi]·· 'WRITE· Register $00
··· SHIFTOUT CANTX, CANCLK, MSBFIRST, [noparse][[/noparse]$00]
··· SHIFTOUT CANTX, CANCLK, MSBFIRST, [noparse][[/noparse]char]
·· HIGH CANCS
·· LOW CANCS
··· SHIFTOUT CANTX, CANCLK, MSBFIRST, [noparse][[/noparse]READspi]
··· SHIFTIN CANRX, CANCLK, MSBPRE, [noparse][[/noparse]CANData]···· 'CHANGE SPI Out to In while CANCS remains LOW
·· HIGH CANCS
·· DEBUG " Reg $00 WROTE ", IHEX2 char, " >>> TEST VALUE = ",· IHEX2 CANData, CR······ 'Verify Result
GOTO TestCAN
I will send you my program in a PM.
I am definitely getting strange results for anything above $7F.
I will have to swap out my MCP2515 chip as I suspect it is defective.
I still have not ruled out that the combined I/O scheme is to blame.
None the less, I am pleased to see you appear completely functional.
You might try writing $80 to the $0e and $0f registers. These are the CANSTAT and CANCNTRL.
In $0e, I get a reply of $01 AND in $0f, I get a reply of $00.
The Microchip PDF says that ALL the registers may be written to after a reset because you are in Configure mode until you change CANCNTRL. CANCNTRL must be %1000 0??? for this mode, but I seem to not be getting there.
Post Edited (Kramer) : 8/4/2006 3:26:26 PM GMT
