PS2 Wireless Gamepad works with BS2 - Heres how
Wireless requires a stricter timing. The Ti timing of "shiftout" command·is too long it needs to be 4 microseconds not 46 microseconds as listed in the help file.
Here have fun :
' {$STAMP BS2}
' {$PBASIC 2.5}
· psxThumbL VAR Byte ' left thumb buttons
· psxThumbR VAR Byte ' right thumb buttons
· psxJoyRX VAR Byte ' r joystick - X axis
· psxJoyRY VAR Byte ' r joystick - Y axis
· psxJoyLX VAR Byte ' l joystick - X axis
· psxJoyLY VAR Byte ' l joystick - Y axis
· idx VAR Nib
· tmpout VAR Byte
· PsxAtt PIN 9 ' PSX joystick interface
· PsxClk PIN 8
· PsxCmd PIN 10
· PsxDat PIN 11
· MAIN:
· DO
··· GOSUB Get_PSX_Buttons
··· DEBUG HOME, BIN8 psxThumbL," ",BIN8 psxThumbR," ",CR'HEX2 psxID," ",HEX2 psxSta,CR
··· DEBUG "psxJoyRX = ",DEC3· psxJoyRX ,CR
··· DEBUG "psxJoyRY = ",DEC3· psxJoyRY ,CR
··· DEBUG "psxJoyLX = ",DEC3· psxJoyLX ,CR
··· DEBUG "psxJoyLY = ",DEC3· psxJoyLY ,CR
· LOOP
[noparse][[/noparse] Subroutines ]
· Get_PSX_Buttons:' This routine REQUIRES inverted clock signal from
··· DIR10=1
··· DIR11=0
··· LOW PsxClk
··· LOW PsxAtt
····· 'GOTO test
······ 'request data
····· tmpout=$01
····· FOR idx=0 TO 7
······· PsxCmd=tmpout.LOWBIT(idx)
······· PULSOUT· PsxClk,2
····· NEXT
····· PAUSE 1
····· tmpout=$42
····· NEXT
····· PAUSE 1
····· tmpout=$00
····· NEXT
····· PAUSE 1
······ FOR idx=0 TO 7
······· psxThumbL.LOWBIT(idx)=PsxDat
······· PULSOUT· PsxClk,1
····· NEXT
······· psxThumbR.LOWBIT(idx)=PsxDat
····· NEXT
······· psxJoyRX.LOWBIT(idx)=PsxDat
····· NEXT
······· psxJoyRY.LOWBIT(idx)=PsxDat
····· NEXT
······· psxJoyLX.LOWBIT(idx)=PsxDat
····· NEXT
······· psxJoyLY.LOWBIT(idx)=PsxDat
····· NEXT
··· HIGH PsxAtt
·· RETURN
END
Here have fun :
' {$STAMP BS2}
' {$PBASIC 2.5}
· idx VAR Nib
· tmpout VAR Byte
· PsxClk PIN 8
· PsxCmd PIN 10
· PsxDat PIN 11
· MAIN:
· DO
· LOOP
··· DIR10=1
··· DIR11=0
··· LOW PsxClk
··· LOW PsxAtt
····· 'GOTO test
····· tmpout=$01
····· NEXT
····· PAUSE 1
····· tmpout=$42
····· NEXT
····· PAUSE 1
····· tmpout=$00
····· NEXT
····· PAUSE 1
····· NEXT
····· NEXT
····· NEXT
····· NEXT
····· NEXT
····· NEXT
··· HIGH PsxAtt
·· RETURN
END
Here's a modified version that doesn't use the transistor in the circuit to invert the clock.
' {$STAMP BS2}
' {$PBASIC 2.5}
· buff VAR Byte(6)
· idx VAR Nib
· idy VAR Nib
· tmpout VAR Byte
· PsxClk PIN 8
· PsxCmd PIN 10
· PsxDat PIN 11
· MAIN:
· DO
··· DEBUG HOME, BIN8 buff(0)," ",BIN8 buff(1)," ",CR'HEX2 psxID," ",HEX2 psxSta,CR
··· DEBUG "psxJoyRX = ",DEC3· buff(2) ,CR
··· DEBUG "psxJoyRY = ",DEC3· buff(3) ,CR
··· DEBUG "psxJoyLX = ",DEC3· buff(4) ,CR
··· DEBUG "psxJoyLY = ",DEC3· buff(5),CR
· LOOP
· Get_PSX_Buttons:
··· DIR10=1
··· DIR11=0
··· High PsxClk ' Change this to low if you use the transistor
··· LOW PsxAtt
··· FOR idy = 0 TO 2
····· LOOKUP idy,[noparse][[/noparse]$01,$42,$00],tmpout
······· PULSOUT PsxClk,2
····· NEXT
··· NEXT
··· FOR idy = 0 TO 5
······· tmpout.LOWBIT(idx)=PsxDat
····· NEXT
····· Buff(idy)=tmpout
··· NEXT
··· HIGH PsxAtt
·· RETURN
END
Have Fun
In the attached image is the standard interface by Jon Williams that appeared in the Nuts & Volts article.
Note it has a transistor on the clock pin - don't need it.
The following section of the second program is the key.
···· High PsxClk ' Change this to low if you use the transistor
if you wish to use the transistor in the diagram change it to this.
···· Low PsxClk ' Change this to high if you omit the transistor.
Jon Williams does recommend that a 220 ohm resistor be used in an output to protect your BS2.
the second attachment below shows that connection
Have Fun
http://www.parallax.com/dl/docs/cols/nv/vol4/col/nv101.pdf
Have Fun
Fake EDIT: nvm, im retarded. i just read thru the code, now i understand how to hook it up.
im going to change the pins thouhg. that way i can have a remote bot, then push x for autonomous, then triangle to return to remote.
and i dont see anything in your code that pulses the servos. i have everything hooked up (except +9) and it recognizes the controller and stuff, but the servos wont move
when i plug +9(grey) into a 9v source, the right vibrator in the contoler turns on (only when i push the analog button)
Post Edited (HavoKane) : 8/5/2006 12:59:47 AM GMT
Have Fun
psxJoyRX = 255
psxJoyRY = 255
psxJoyLX = 255
psxJoyLY = 255
that shows up in the debug window. no buttons do anything. i tried it on 2 different contollers
' {$STAMP BS2}
' {$PBASIC 2.5}
· buff VAR Byte(6)
· idx VAR Nib
· idy VAR Nib
· tmpout VAR Byte
· PsxAtt PIN 9
· PsxClk PIN 8
· PsxCmd PIN 10
· PsxDat PIN 11
· Servo· PIN·12··· 'assuming it is on pin 12
· ServoPos ·VAR· WORD
· MAIN:
· DO
····ServoPos··=buff(4) *·2 + 500
··· ServoPos··=ServoPos··MIN·500
··· ServoPos··=ServoPos··MAX·1000
··· PULSOUT Servo,·ServoPos
··· PAUSE·10 ' reduce or remove this pause if servo acts erratic
··LOOP
· Get_PSX_Buttons:
··· DIR10=1
··· DIR11=0
··· LOW PsxAtt
····· NEXT
··· NEXT
····· NEXT
··· NEXT
··· HIGH PsxAtt
·· RETURN
END
Have Fun
Oh and of course your code.
Have Fun
Post Edited (TechnoRobbo) : 8/5/2006 1:35:26 AM GMT
i did.
sorry, i dont have a camera, so i drew a schematic in mspaint. lo
the code is yours, copy + paste
Post Edited (HavoKane) : 8/5/2006 1:45:21 AM GMT
Have Fun
i have the parallax modified servos (continous)
Have Fun
' {$PBASIC 2.5}
buff VAR Byte(6)
idx VAR Nib
idy VAR Nib
tmpout VAR Byte
PsxAtt PIN 9
PsxClk PIN 8
PsxCmd PIN 10
PsxDat PIN 11
Servo PIN 12 'assuming it is on pin 12
ServoPos VAR WORD
MAIN:
DO
ServoPos =buff(4) * 2 + 500
ServoPos =ServoPos MIN 500
ServoPos =ServoPos MAX 1000
PULSOUT Servo, ServoPos
PAUSE 10 ' reduce or remove this pause if servo acts erratic
LOOP
Get_PSX_Buttons:
DIR10=1
DIR11=0
LOW PsxAtt
FOR idy = 0 TO 2
FOR idx=0 TO 7
PULSOUT PsxClk,2
NEXT
NEXT
FOR idy = 0 TO 5
FOR idx=0 TO 7
PULSOUT PsxClk,2
NEXT
Buff(idy)=tmpout
NEXT
HIGH PsxAtt
RETURN
END
the servo just sits there and spins. the controller does nothing
i have a wire controller plugged in becuase the wireless one was too expensive. does your code not work with wired controllers?
Post Edited (HavoKane) : 8/5/2006 2:14:04 AM GMT
' {$STAMP BS2}
' {$PBASIC 2.5}
· buff VAR Byte(6)
· idx VAR Nib
· idy VAR Nib
· tmpout VAR Byte
· PsxAtt PIN 8
· PsxClk PIN 9
· PsxCmd PIN 10
· PsxDat PIN 11
· Servo· PIN 12··· 'assuming it is on pin 12
· MAIN:
· DO
··· IF buff(5)<80 THEN
····· PULSOUT Servo,1000
··· ELSEIF buff(5)>160 THEN
····· PULSOUT Servo, 500
··· else
····· PULSOUT Servo, 750 ' or whatever your stop position is
··· endif
··· PAUSE 10 ' reduce or remove this pause if servo acts erratic
· LOOP
· Get_PSX_Buttons:
··· DIR10=1
··· DIR11=0
··· HIGH PsxClk ' Change this to low if you use the transistor
··· LOW PsxAtt
····· NEXT
··· NEXT
····· NEXT
··· NEXT
··· HIGH PsxAtt
·· RETURN
END
Have Fun
and the servo movement is kinda erratic. even if i cahnge/remove the pause statement. and the servos doesnt stop moving if i let go of the joystick.
Post Edited (HavoKane) : 8/5/2006 2:27:57 AM GMT
' {$STAMP BS2}
' {$PBASIC 2.5}
· buff VAR Byte(6)
· idx VAR Nib
· idy VAR Nib
· tmpout VAR Byte
· PsxAtt PIN 8
· PsxClk PIN 9
· PsxCmd PIN 10
· PsxDat PIN 11
· MAIN:
· DO
··· else
····· PULSOUT Servo, 750 '<
Please·Note
··· endif
· LOOP
· Get_PSX_Buttons:
··· DIR10=1
··· DIR11=0
··· LOW PsxAtt
········TOGGLE PsxClk·· ' note the change
······· TOGGLE PsxClk
····· NEXT
··· NEXT
····· NEXT
··· NEXT
··· HIGH PsxAtt
·· RETURN
END
Have Fun
Have Fun
Have Fun
use the Jon williams code (http://www.parallax.com/dl/docs/cols/nv/vol4/col/nv101.pdf) if your using the transistor it will execute faster.
Have Fun
the actual amount is 20 but the extra instruction add a delay. - I use the PSC servo controller so I dont have to bother with all that.· Leaves more time for the meat of the program.
http://www.parallax.com/detail.asp?product_id=28023
trust me you wont regret buying it
Have Fun
I have tried your code with a wired PS2 controller (logitech). It works fine.
I switched it with a logitech and a madcarz wireless controller. Nothing happens.
I use the schematic with the transistor.
Any suggestions?
michael
2. Note that the 7.6V (commanly referred to as the 9v pin) Green wire Pin 3 has been reported to be necessary on some controllers.· The pelican doesn't need it though.· I can publish the rumble code if someone wants it.
3. also I did not include the code for automatically turning on the analog mode so make sure you do that manually.
Oh what the heck here's the code
·' {$STAMP BS2}
' {$PBASIC 2.5}
'i/o config
· 'BUFF VAR Byte(3)
· PW· VAR Word
· buff VAR Byte(6)
· PsxClk PIN 8
· PsxCmd PIN 10
· PsxDat PIN 11
·'--equates---
· tmpout VAR pw.LOWBYTE
· idx·· VAR pw.NIB2
· idy·· VAR pw.NIB3
· 'inits
··· PAUSE 250 'give controller time to initialize··
··· OUTPUT PsxCmd
··· INPUT PsxDat
··· LOW PsxClk
··· LOW PsxAtt
··· FOR idy = 0 TO 8
····· LOOKUP idy,[noparse][[/noparse]$01,$43,$00,$01,$00,$00,$00,$00,$00],tmpout
····· GOSUB BitSend
··· NEXT
··· HIGH PsxAtt
··· PAUSE 1
··· LOW PsxAtt
····· LOOKUP idy,[noparse][[/noparse]$01,$44,$00,$01,$03,$00,$00,$00,$00],tmpout
····· GOSUB BitSend
··· NEXT
··· HIGH PsxAtt
··· PAUSE 1
··· LOW PsxAtt
····· LOOKUP idy,[noparse][[/noparse]$01,$43,$00,$00,$00,$00,$00,$00,$00],tmpout
····· GOSUB BitSend
··· NEXT
··· HIGH PsxAtt
··· PAUSE 1
· '[noparse][[/noparse]$01,$43,$00,$01,$00,$00,$00,$00,$00]'config mode enter
· '[noparse][[/noparse]$01,$44,$00,$01,$03,$00,$00,$00,$00]'set analog
· '[noparse][[/noparse]$01,$4D,$00,$00,$01,$ff,$ff,$ff,$ff]'Vibration Enable
· '[noparse][[/noparse]$01,$43,$00,$00,$00,$00,$00,$00,$00],'config mode exit
· 'program
· MAIN:
· DO
··· DEBUG HOME,BIN8 buff(0)," ",BIN8 buff(1) ,CR
··· DEBUG DEC3 buff(2)," ",DEC3 buff(3) ,CR
··· DEBUG DEC3 buff(4)," ",DEC3 buff(5) ,CR
· LOOP
··· OUTPUT PsxCmd
··· INPUT PsxDat
··· LOW PsxClk
··· LOW PsxAtt
····· GOSUB BitSend
··· NEXT
····· NEXT
····· buff(idy)=tmpout
··· NEXT
··· HIGH PsxAtt
·· RETURN
· BitSend:
··· FOR idx=0 TO 7
···· NEXT
··· RETURN
Have Fun
Post Edited (TechnoRobbo) : 8/6/2006 8:07:22 AM GMT
