simple SX/B question
Hello, i'm new to the SX, and i have a simple question that i can't figure out.
I would like to use code similar to the following:
I would like to use a variable to identify a pin. But this code doesn't work. Is there some way i can get something like this to work, without using if-then statements?
Alex Hunter
for idx = 0 to 7
HIGH RA.idx
next
Alex Hunter
My apologies gang.· I just realized that my answer was so far off that it was flat out wrong ... thus I deleted it so that it doesn't get used.· Bean gave much better advice in the next message.
John J. Couture
San Diego Miramar College
Post Edited (John Couture) : 8/3/2006 5:36:29 AM GMT
· You cannot use a variable for the bit position. This is because of the way the SX instructions are formed.
· Probably the easiest way is to do this:
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
I found your trick the hard way last week. I thought I was real stupid finding no other way but by using the OR function. it makes me feel a little better seeing you're using it.
John Bond
Bean.
Using the 'Bean' strategy, is there a similar way we can access the individual bits using an index, instead of shifting a byte?
For example if I wanted to test individual bits of a byte:
idx VAR BYTE
mybyte VAR BYTE
FOR idx = 0 TO 7
IF mybyte.idx = 1 THEN ' which won't work
'do somethin'
ENDIF
NEXT
An array of bits was another idea, but the compiler didn't like it.
Kinda like mybyte.LowBit(idx)) for the BS2 code.
Thanks!
idx VAR BYTE mybyte VAR BYTE tempByte VAR Byte FOR idx = 0 TO 7 tempByte = 1 << idx tempByte = tempByte AND myByte IF tempByte <> 0 THEN 'do somethin' ENDIF NEXTBean
Ah yes, being tricky with bytes! I was thinking that there were some functions using or accessing bits like in PBASIC other than mybyte.1.
many thanks!
Bean.
