Help IDE-0052 Error Additional Information
I ran Project\Identify on both a working chip and the non working chip.· Here are the results:
Port··· Device Type··· Version···· Loopback···· Echo··· Got Status
COM1· Javelin··········· $50·········· Yes··········· Yes········ Yes
The above results are for the working Javelin.
Port··· Device Type··· Version···· Loopback···· Echo···· Got Status
COM1··· <blank>······· $05··········· Yes··········· No·········· No
These results were obtained from the non-working Javelin.
Thanks again for your assistance.
I suspect the not responding javelin is damaged.
If you have seperate setups for both javelins,
try inserting the not responding javelin into
the setup of the responding javelin.
Since the not responding javelin does not have any echo
makes me suspect the onboard regulator. Does the
not responding javelin output 5V on pin 21 ?
regards peter
