Help - Error IDE-0052
I am receiving an Error IDE-0052 when attempting to program a Javelin Stamp.· It further tells me it is an "Incompatible Firmware Revision ($5)"· I have powered it off and restarted both the IDE as well as leaving the IDE running when I repowered the Javelin only.· No change in results.
Really need some help here as this is the first time I have seen it.· The chip numbers are the same as on a Javelin that I can program without any problems.
The IDE is version "2.0.3 build 0 for stamp version $5x"
Any help would be greatly appreciated.
Carey
Carey
a usb2serial cable. If using such· a cable, what brand/type?
regards peter
I am using a regular RS-232 connection on COM1..
Hope this helps
Carey (CarSta)
