connecting a digital high/low signal to an external 9v circuit — Parallax Forums
joshuazvijoshuazvi Posts: 11
edited 2006-08-04 20:02 in BASIC Stamp
hi,
i would like to use an i/o pin from the basic stamp to turn on an alarm siren. the problem is it isnt strong enough to do it on its own. i have been having problems with relays. are there digital logic relays that can switch on other circuits? please help! thanks,
josh
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2006-08-02 18:59
    Josh -
    What you probably want is an SSR or solid state relay with a 5-6 volt "coil" and contacts appropriate for your alarm siren. If you need help sourcing them, just ask.
    Bruce Bates
    <!--StartFragment -->
  • T ChapT Chap Posts: 4,249
    edited 2006-08-02 20:42
    also try a mosfet for switching, you could google up mosfet switching, they are easy to hook up and cheap.
    here area few links
    http://www.physics.udel.edu/~watson/scen103/mos3.html
    http://www.physics.udel.edu/~watson/scen103/mos4.html
  • joshuazvijoshuazvi Posts: 11
    edited 2006-08-04 17:05
    bruce,
    thanks for your advice. i actually am having a problem finding them. i must have scrolled through 100 relays on jameco. i have bought 3 relays in the past none of which worked, i'm afriad i just have no idea which relay i need.
    thanks
    josh
    edited 2006-08-04 18:20
    Josh -
    Crydom makes almost any type of SSR you can imagine. Make your selection of type from there, and then go checking supplier web sites. Here is a link to the Crydom web site:
    http://www.crydom.com/products/productFamilyList.aspx?idProductLine=3
    Bruce Bates
  • AmaralAmaral Posts: 176
    Have you consider switching the relay from the Vin using an npn transistor ?
    Amaral.
