Recommended Additions to SX/B Online Help
In the SX/B help file (Reference / Definitions), it might help to·add to the "Variables" section.·
There is an example of a word variable IDX being split into the LSB by use of idx_LSB but there isn't any other mention of that in the formal definition above.· I found it by just guessing that MSB is also available.· Is there a way to indicate that:
·· Symbol···· ·VAR· Word
······can also be addressed as
·· Symbol_LSB· VAR· Byte
·· Symbol_MSB· VAR· Byte
A little lower down ther is a mention of:
wordVar = lsbValue, msbValue
Am I correct in assuming the lsbValue and msbValue are just arbitrary names that indicate that the lsb should always be in the first position?
John J. Couture
San Diego Miramar College
John J. Couture
Yes, the aliases wordvar_LSB and wordvar_MSB are automatically created for any word variable.
Let's say you have a bytevar and you want to make a wordvar = bytevar * 256. You could do
wordvar = 0, bytevar
This would be the same as:
wordvar_LSB = 0
wordvar_MSB = bytevar
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
