Loading EEPROM file into RAM
Yo...
Here's what I want to do. I'm using this source for reading from an SD card. What I want to do is read an EEPROM file (exported from the Propeller tool) into RAM from the SD card. From my understanding, I can use the pgetc command to read the file byte by byte. But how do I load it directly into RAM?
iam7805
iam7805
Heh, I was expecting that it would require some assembler.
But how would I do this if I wanted to load a full 32kb program into RAM?
As assembly routines run completely self contained in the COGs, there's then no issue with completely replacing the entire contents of the shared memory.
Definetly a E3 (Electronics Engineer Extrodinare!)
"I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
