Legs on Robot
Has anyone built a robot with·legs that fold in the middle? I see lots of robots that have 6 legs with knees but not many that fold. In other words the robot would look like an M from the end or an upside down U when extended. I guess spider like would be a good term.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
http://www.lynxmotion.com
·They have kits with elec, with servos only, or bare bones where you would have to supply your own servo's, and elec.
I'm considering this one.... http://www.lynxmotion.com/Category.aspx?CategoryID=28
This is how it would look with a low body
·· l\·································· /l
·· l· \·······························/· l
···l·· ·\···························/··· l
·· l····· \·······················/····· l
·· l······· \___________/········l
·· l·········l___________l······· l
·· l····································· l
· With legs that could extended upward it would look more like this
·············· __________
·· ______l____________l_____
· l········································ l
··l········································ l
· l·········································l
· Anyone seen anything like it?
Post Edited (AIman) : 7/29/2006 3:51:23 AM GMT
You could build your own simpler version using only 4 legs, 1 servo to raise/lower each leg and 1 to pivot forwards/backwards, so it only uses 8 servos.
In other words a biped with a knee would require 2 servos but a M shaped leg like I diagramed above would be a 3 servo knee.
Am I following that correctly?
Dave
Dave Andreae
Tech Support
