how to measure longer time?
I want to measure the time between events that are measured by a hall-effect sensor. Normally the signal is logic HI, with logic LO pulses. I want to measure the time from one logic LO to the next. Usually the time will be less than 300ms.
I looked at the PULSIN command, but for my project the measurement times need to be greater than 131ms (which is the maximum time measured by PULSIN on the BS2 that I have).
Is there a different way to measure time with the BS2?
BS2 is here for the world
and
the world is here for the BS2
