Questions...
Okay, I'm new to this type of controller, and I need a few questions answered.·
1. Am I able to use PBASIC to program the controllers?
2. Is there any separate circuitry on the development boards to program it, or can I connect the SX key directly to the right pins?
3. Is the pin setup the same as the Basic stamps?
4. Is it reprogrammable
Post Edited (computer_geek) : 7/27/2006 2:50:14 AM GMT
2) If you have the SX-Key you just need to connect the OSC1 and OSC2 pins on the SX chip to the pins on the SX-Key. Make sure you have 10K pull-up resistor on the MCLR pin.
3) You can use INPUT and OUTPUT like PBASIC. To set a whole port is different though.
4) Of course. It has flash memory.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"The meaning of life, is to give life meaning" Unknown.
