Propeller QFN Land Pattern HERE!!!
cgracey
Here is the land pattern for the QFN package. The LQFP will be ready, too, shortly.
Chip Gracey
Post Edited (Chip Gracey (Parallax)) : 7/27/2006 1:13:28 AM GMT
Chip Gracey
Sid
Chip Gracey
Chip Gracey
Sid
I too, would be interested in the SOIC package. How much smaller would a SOIC be from the DIP (if it were materialized)?
-Parsko
Sid
the .4 is the width, 1.8 is the length, but the 44? Is that the pin count?
Propeller + Hardware - extra bits for the bit bucket =· 1 Coffeeless KaosKidd
Sid
-Dan
I need a REAL layout program...
THanks Chip for posting the specs...
I looked into this and I cannot find a packaging supplier who does 40- or 44-pin SOIC. I think this is no longer done. All I can find are expensive ZIF sockets.
Anyway, the LQFP is intended to be the surface-mount version of the Propeller which can be hand-soldered easily. You just have to get some flux on the legs and drag your iron across them. If you've never done this, you'd be amazed at how well it works. We use water soluble flux here, so it rinses right off.
To solder a QFN part by hand, you need to get some solder bumps on its pads using a hot-air pencil, apply some extra flux, position the part and heat up the board and QFN with hot air. The LQFP is much easier to deal with by hand. In production, when using a solder stencil, paste, a pick-and-place, and reflow oven, it's all the same. The QFN is just cuter. It takes one-half the area of the LQFP because it's only 9x9mm and doesn't have any legs sticking out. We would have used the QFN on the demo board, but then people wouldn't be able to probe the pins.
Chip Gracey
Sid
Chip Gracey
http://www.howardelectronics.com/xytronic/Images/Drag%20Soldering%20107.wmv
Post Edited (Paul Baker) : 7/28/2006 4:43:25 AM GMT
If so, I might be able to do this...
Sid, do you know if you can share lib's with expresspc? If so, I'd love a copy of that foot print...
Express540\PCBComponents_Custom
Sid
Sid
Thanks... I'll check it out when I get home... (Aug 13...)
Sid
Sid
Sid
Sid
Even if they are, it's a good practice to connect them all on the PCB, too. At least one pair should be bypassed near the chip, as was done on the Demo Board. But it certainly wouldn't hurt to put bypass caps on all four sides if you've got the room.
Sid
Sid
http://www.cadsoftusa.com/
And no, I don't work for them.· [noparse]:)[/noparse]
Chip Gracey
