SXSim Support?
Anybody know if there is any direct SXSim support?
When I click on the Icon to open it up, it shows the registers, commands, and code windows...but there are no controls for it, and the command window is not opening up.· The command window shows in my taskbar, but I am not able to interact with it in any way.
Here is the screenshot.· Notice "Commands" is my 'active' window.
http://i16.photobucket.com/albums/b45/lifejustice/Untitled-1.jpg
Shaun
Shaun
I have defined the command window to always stay on top, so you normally should see it, and be able to use the command buttons inside.
SXSim saves the positions of the various windows in the SIM files it creates for each LST file you open. Maybe, a SIM file is corrupted so that SXSim restores the command window outside the phsical coordinates of your screen. Please delete the SIM files, and then try again.
In the moment, I'm on vacation in the US, so I can't try to reproduce your problem right now. If you can't get SXSim working as expected, please drop a message, and I'll take care of the problem when I'm back in Germany on August 08.
Greetings from Germany,
G
