stamp protection - optoisolation?
Hi all,
I am working on an industrial control project·which involves the use·of a bs2p40·connected to 1-wire·devices which interpret thermocouple data.· How should I decide if it is necessary to use optoisolation on the 1-wire bus?·
The only exterior contact·with the outside world·is the connectors to the thermocouples.· These are rugged (omega)·male-female, which, on the micorcontroller end, don't really allow anything else to be accidently connected.·
If by any chance a high current was forced·through the connection can I assume that the 1-wire device would blow first protecting the stamp?
If isolation is a must, what single part could be used to keep component count minimal?· All info I have seen describe medium to large sized circuits to provide isolation.·
Thanks for your help,
Frank·····
Frank·····
When you say "1-wire" are you speaking of the Maxim/Dallas proprietary One Wire protocol? If so the answer is opto-isolation, at present, is not supportted, but the Maxim/Dallas engineers are presently working on a solution for that very problem. This comes from an inquiry I made to them last week, so the information is current.
Bruce Bates
<!--StartFragment -->
1-wire·= I2C and invented by Philips.
Marcel
"1-wire" is NOT I2C. I2C is a two wire interface.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Beyond what Bean correctly said, "1-wire" is a proprietary and patented interface designed by and owned by Maxim/Dallas:
http://www.maxim-ic.com/1-Wire.cfm
Bruce Bates
Marcel
