Tlc555
okay i used the thing in the post by stephanie Lindsay http://forums.parallax.com/attachment.php?attachmentid=42602
i tried to follow this schematic and im not sure if i followed it right.... i know i didnt i think im messing up where the wires connect at a 180 deree angle that come to a T does that mean it goes on the same breadboard row as if one that isnt at a T? for instance if you look at the schematic you will see Vcc connects to vdd and another wire· from the 470 resistor also does... does that mean it hooks to the same row as pin 8 or goes to Vdd also?
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
Keep in mind that a schematic is different than a wiring diagram. A schematic is not going to tell you which thing to connect to which breadboard row. It's just showing you electrical connections. It's up to you to determine how to accomplish those connections on your breadboard. For example, the other end of that 470-Ohm resistor could go to the Vdd bus on your breadboard or it could go to the same row as pin 8 with a jumper wire going from that row to the Vdd bus. The only thing that matters is that there is a direct connection between the resistor's lead and Vdd.
links:
My band's website
In the meantime, there are a few circuits here: ourworld.compuserve.com/homepages/Bill_Bowden/homepage.htm
There's a Forrest Mims book: www.amazon.com/gp/product/0945053290
If you do a Google search on "555 tutorial" or "555 circuits" you will come up with enough stuff to keep you busy for a little while.
links:
My band's website
I have attached a real nice websight about the 555 chip it has many examples of how to use it..
http://home.cogeco.ca/~rpaisley4/LM555.html
