Boe-Bot on two wheels....
im trying to figure out how to get the boebot to balance on two wheel vertically using the components supplied from the boebot book and the WAM book.... any ideas? i also have a extra Receiver module for IR
You will need to use a tilt sensor of some sort to let you know what position the platform is in. Then, based on that feedback information, you will need to more forward or backward to keep the platform balanced, presuming it has a reasonable balance point to begin with.
This is a fairly advanced project, if you are new to Stamps.
Bruce Bates
<!--StartFragment -->
2 Wheels Balancing Robot
Regards Thanos
Greekbotics: Greek Robotics Forum
(Translate it using Babelfish)
