High Current PC Board
crgwbr
Hey Everyone,
I'm Building a motor controller for a rather large BS2 controlled bot (50+ Pounds).· I can handle designing the boards, thats no problem; what has me stumped, is how to put high current through a PC Board.· The most I've ever put through one is 5 A.· I've though of jumper soldered over the traces, would this work?· Any other suggjestions?
NerdMaster
For
Life
NerdMaster
For
Life
· You want the contact to be metal-to-metal, a true physical connection,·and not basically·through solder.· You only want solder to re-inforce/aid the connection, not to make it.
I am by NO means a draftsman or artist, but the attached rudimentary drawing ought to give you the idea of what PJ was saying, in relative terms. The BROWN areas are PURE COPPER and the SILVER/GRAY areas are solder-on-copper. The machine screws indicated could just as well be a nut-bolt-washer set-up as PJ suggested.
Bruce Bates
It all depends on how much voltage drop you are able to tolerate. Generally if I have more than a couple of amps flowing on a steady basis (pulses may be more tolerant) then I "beef up" the copper trace by forming and soldering overtop of it a sturdy piece of buss wire, 18 or in some heavy current cases even 16 ga. The joint is also completely filleted with solder, giving the effect of an even heavier wire.
Where needed, it works great.
Cheers,
Peter (pjv)
http://www.saturnpcb.com/Software.htm#3
Post Edited (bennettdan) : 7/23/2006 10:32:38 PM GMT
NerdMaster
For
Life
I have a power supply board I use for powering industrial motion control Servo Motors.
It is 15 amps at 80 volts DC. I usually use Express PCB for my boards. but they only have 1 Oz. copper.
For this board, I use Pad2Pad (www.pad2pad.com).
It is a little more expensive than Express PCB, but it fits my needs.
They have 2 Oz. copper boards. I use .150 traces bottom and top for the power traces. This board handles the surges up to 50 amps for a second. There is lots of capacitors in my design.
·If you give a 2 week lead time the boards are not too expensive, and look much better than soldering wires onto traces.
Alan Bradford
Plasma Technologies
www.plasmatechnologies.com
·fo now.
NerdMaster
For
Life
Why dont you find a mosfet with a Isotop so you can have screw connections to your motor? They are not to costly if you look ..you can buy them for about 20 from digikey..
NerdMaster
For
Life
NerdMaster
For
Life
