PS2 Mouse and Keyboard connections not working on Propstick ?
I have wired up 2 PS2 cables as indicated in the Propeller Demo Board schematic using the 100 ohm and 10K ohm resistors as drawn. However, I can not get any of the mouse or keyboard related programs to work (no activity on either). I have done a full continuity and ohm check on all the connections and everything checks out well. All I see on power up is the Keyboard LED's for num lock, caps lock and scroll lock turn on briefly as they should and then go off. This tells me that power is connected correctly. I am using a brand new Radio Shack PS2 keyboard and new Radio Shack PS2 mouse. I·unsoldered a new USB to PS2 cable adapter ($22) as PS2 cables are not easy to find·cheaply. ·All the connections check out from the end of the PS2 connector to the P24 - P26 connections including the 100 and 10K ohm checks.
Where else should I look for a problem or is there a problem with the schematic or something?
Thanks for your help.
I have both the keyboard and mouse working now. The Schematic is a little misleading and possibly wrong.
I had to swap the DATA and CLOCK wires on both the mouse and keyboard. Now it works great. Also make sure the 10K resistors are going to 3.3v from the propeller chip - not 5v.
Thanks.
