Servo Control
Hello,
···· I would like to if the SX chips are·able to control a servo with a pot? I·usually use the BS2 for most projects but I am going to buy this ·http://www.parallax.com/detail.asp?product_id=45181·SX tool kit would this provide a good·start? Thanks for any advice..·
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"Remember, you are unique, just like everyone else." Unknown.
The PULSOUT command has 10uSec resolution not matter what the clock speed.
So "PULSOUT Servo, 150" will generate a 1.5mSec pulse which should center the servo.
DO
· PULSOUT Servo, 150
· PAUSE 20
LOOP
Bean.
Does the SX use RCtime to read a pot or some other command I cant seem to find it in the manual..
SX/B has the RCTIME command.
There isn't a manual for SX/B (that I know of).
The help file has all the commands and examples in it.
From the IDE choose "HELP" from the top menu then choose "SX/B HELP"
Bean.
From a practical standpoint, your routine in the loop would have to get pretty long before the servo has enough time to drift very far. I also belive this "problem" is gone if you use "digital" servos.
John R.
8 + 8 = 10
http://www.parallax.com/dl/docs/prod/sx/SXKeyMan2_0.pdf
Sorry
