Which IR sensor is easier to work with? — Parallax Forums
bulkheadbulkhead Posts: 405
edited 2006-07-19 05:51 in General Discussion
I am looking at the Sharp line of IR sensors. I can't decide between the digital or analog one. It says the digital one outputs, "a serially transmitted byte proportial (not linearl) to the distance to the nearest object in its field of view" and the analog one outputs, "an analog voltage proportional to the distance to the nearest object in its field of view." Which one of these would work best with the javelin? I would suppose that with the digital one, a Uart would be used to communicate. With the analog one, the voltage would just be read. Also, are both non-linear? Thanks.
