Current Limiting Resistors to LED Ratio
I have an attached schematic.
It is a Voltage Source that supplies 250mA.
There are 32 LED's attached to it.· I would like to limit the number of resistors on the circuit.· The resistors that I am using are 1/4W resistors.· With 32 LEDs on 250mA, Each LED will only be using about 7mA.
With this low of current on Each LED, and 1/4w resistors, shouldn't I be able to use just 1 resistor for say 8 LEDs?
I have attached the schematic showing 32 LEDs and 8 resistors (2 resistors for every group of 8).·
What do you guys think?· Am I pushing some Power boundaries, or does this look OK?
Sorry about all of the questions today.·
Shaun
Shaun
You don't say what voltage the power supply is ???
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"Remember, you are unique, just like everyone else." Unknown.
