Voltage Divider to change 12V to 5V
Hey, guys...
··· I am working on a circuit that has a clean, filtered 12V input.· there is one component in the circuit that has a maximum Input Voltage of 6 Volts.· I have VERY LITTLE room for components and I am very cramped.
··· Does it seem feasible to just use a voltage divider with a 330ohm resistor and a 220ohm resistor (bringing voltage down to 4.8V?· If the input Voltage is clean and filtered, idealy the output of the divider should be stable enough...am I correct?
-circuit attached
-circuit attached
· It's not recommended to to that.
· The reason is that the voltage will change according to how much current the IC is using.
· If it's a gate there is a good possiblity that it will oscillate too.
· I can see it causing all kinds of problems.
· You could probably get away with using a resistor and zener diode.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"Remember, you are unique, just like everyone else." Unknown.
