Reading input on programming port for BS2pe
Hi, I wrote up a program for basic stamp that requires a one byte number input (i.e. 0-255) in the debug window to make a choice which corrsponds to an action. That program works fine. However, I want to write up another program in Visual Basic 6 to be the interface. I've written the VB6 program and it "supposedly" connects using the MSComm feature of Visual Basic. However, when I send commands, the basic stamp does not respond. I am trying to send these commands via the same Comm Port (1) which is the programming port. So basically Comm Port 1 / RS232.
To do so, I have to first close the debug window or else there will be program conflict and i won't be able to connect with my VB6 prog.
I am quite sure I am communicating with the right baud rate, parity (9600, n, 8, 1) etc. with my VB6 program. I even tried inserting a carriage return after each digit output but to no avail. In VB6, I simply use "MSComm1.Output = Chr$(10)" where 10 corresponds to a menu option in my basic stamp program.
Is there something else that I should do when communicating with basic stamp without the debug window?
Thanks in advance!
Thanks in advance!
The only one that I'm certain of is #89, which can be downloaded here:
www.parallax.com/html_pages/downloads/nvcolumns/Nuts_Volts_Downloads_V3.asp
You'll have to look for the others in the downloads.
Edit:
Okay, here is a list of the NV cloums that mention VB in some way:
17, 41, 42, 43, 44, 63, 64, 88, 89, 93, 105, Overview
Post Edited (Kevin Wood) : 7/18/2006 12:20:56 AM GMT
csavage@parallax.com
2. I think there's an MSComm setting which says how many bytes need to be in the buffer before data is actually sent out the serial port. You need to set that to zero.
Oh, and here's a working example -- but I think it's mostly to 'listen' to a BS2.
Post Edited (allanlane5) : 7/18/2006 5:12:04 PM GMT
