Pool Skimmer Project
I am working on a pool skimmer that is remote controlled but I would like to make it Autonomous so I can let it run by itself and it will be able to avoid hitting objects and the sides of the pool. I am looking into Microcontrollers and how to program them. Can anyone recommend a parallex micro controller that will be easy for begineers to use? I will have 2-3 sensors on the front of the skimmer and I want to have a basic operation. When sensor A is blocked the skimmer will turn in a specified direction and when sensor B is blocked it goes in another direction...you get the point. Any recommendations or suggestions/reading material that can help?
Not looking for long range sensing, just avoidance. I like the idea of a surface skimmer and figure you are planning on following the side of the pool. Was wondering if the same priciple could be applied to an underwater cleaner?
Just curious, please don't flame me!
"Never create anything you can't control"
"The amount of intelligence on the planet is fixed... the population is growing"
Similar prop. design:
http://www.gizmodo.com/gadgets/gadgets/remote-control-boatpool-skimmer-178857.php
As far as which microcontroller to use, there is a seemingly-endless supply of source code and reference material out there for the BS2 series, but the new Propeller chip is a lot more powerful. Since the Propeller is so new, though, there isn't as much support material yet. These forums are a great resource for either chip.
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
