IR Buddy Communication
Hey all this is my first post but have been familiar with the forums for a while. Let me start by introducing myself. I am a mechanical engineering student doing research at UNM. A multi-agent robot project has been initiated and I have decided to use IR as one of the methods of communication in addition to bluetooth (if i can ever get eb500s that are not duds). I have the source code for a master and slave application.
The master sends 8 bits of data in packets and is error checked, standard procedure I understand. If the packet was good the slave acts on the command by lighting up 4LEDs and counting in a binary fashion to 15.
What I want to be able to accomplish is, instead of send data to pins 0-3 and light up LEDs, I want to send commands to pins 12 and 13 to move the motors for certain durations. I would also like to send sensor data to the slave such as sonar sensor readings, or temperature readings. All the code and documentation is on IR buddy page. I have included the master and slave program for convenience. Again all I need to do is send data to different pins or if the packet can tell the slave what subroutine to perform that would be even better. Thanks for any help!
File...... IRB Master.BS2
' Purpose... Buffered serial comms with IR Buddy
' Author.... Parallax, Inc.
' E-mail.... stamptech@parallaxinc.com
' Started...
' Updated... 25 NOV 2002
' {$STAMP BS2}
' {$PBASIC 2.5}
' Program Description
' This program sends a command and data in an eight-byte packet to a slave
' device. The slave can act on the command and send data back.
' Note: For best performance, shield IR Buddy from external interference
' Revision History
' I/O Definitions
IRbSIO PIN 15 ' IR Buddy serial I/O
TxLED PIN 0 ' transmitter on indicator
' Constants
IRbDataTx CON $44 ' 8-byte data transmit
IRbDataRx CON $64 ' 8-byte data receive
IRbMod CON 38 ' modulation freq: 30, 38 or 56
IRb96 CON 84 + $8000 ' 9600 baud, open
IRb48 CON 188 + $8000 ' 4800 baud, open
IRb24 CON 396 + $8000 ' 2400 baud, open
IRbBaud CON IRb96
STX CON $02
ACK CON $06
NAK CON $15
ErrHeader CON %0001 ' bad header
ErrChkSum CON %0010 ' bad checksum
ErrCommand CON %0100 ' invalid command
ErrSlave CON %1000 ' bad slave packet
LightLeds CON $C0 ' commands for slave
LedsOff CON $C1
Busy CON 0 ' IR Buddy is transmitting
' Variables
buffer VAR Byte ' tx-rx buffer (8 bytes)
cmd VAR Byte
data1 VAR Byte
data2 VAR Byte
data3 VAR Byte
data4 VAR Byte
data5 VAR Byte
chkSum VAR Byte
header VAR buffer ' tx header
ackByte VAR buffer ' rx status
lastCmd VAR Byte ' last command sent
rxChkSum VAR Byte ' comparison checksum
errorLevel VAR Nib ' possible packet errors
counter VAR Nib ' counter for slave display
idx VAR Nib ' loop counter
' EEPROM Data
' Initialization
Setup:
PAUSE 250 ' let DEBUG window open
DEBUG CLS
DEBUG "IR Buddy Master-Slave Demo", CR
DEBUG "--------------------------", CR
DEBUG CR
DEBUG "TX: ", CR
DEBUG "RX: ", CR
DEBUG CR
DEBUG "Status: "
' Program Code
Build_Packet:
GOSUB Clear_Buffer
header = STX ' build TX packet
cmd = LightLeds
data1 = counter
GOSUB Make_CheckSum
GOSUB Show_TX_Packet
lastCmd = cmd ' save for RX check
TX_Packet:
GOSUB IR_Buddy_Reset
HIGH TxLED
SEROUT IRbSIO, IRbBaud, [noparse][[/noparse]IRbDataTx, IRbMod, STR buffer\8]
PAUSE 5 ' let IRB grab SIO line
TX_Wait:
DO WHILE (IRbSIO = Busy) : LOOP ' wait for TX to end
LOW TxLED
RX_Packet:
SEROUT IRbSIO, IRbBaud, [noparse][[/noparse]IRbDataRx] ' prep for 8-byte RX
SERIN IRbSIO, IRbBaud, 1000, TO_Error, [noparse][[/noparse]STR buffer\8]
GOSUB Show_RX_Packet ' display received bytes
Check_RX_Packet:
errorLevel = 0 ' clear previous errors
IF (header = ACK) THEN
rxChkSum = chkSum ' save rx checksum
GOSUB Make_CheckSum ' calc checksum of rx packet
IF (rxChkSum <> chkSum) THEN ' compare checksum values
errorLevel = ErrSlave | ErrChkSum ' bad checksum from slave
ENDIF
ELSE
IF (header = NAK) THEN
errorLevel = data1 ' get errors from packet
ELSE
errorLevel = ErrSlave ' slave packet bad
ENDIF
ENDIF
Status_Report:
DEBUG CRSRXY, 8, 6 ' move cursor
IF (errorLevel = 0) THEN
DEBUG "Good Packet", CLREOL
counter = (counter + 1) & $0F ' update counter
PAUSE 500
ELSE
IF (errorLevel.BIT3) THEN ' bad slave packet?
DEBUG "Bad packet from slave", CLREOL
ELSE
DEBUG "Slave returned NAK", CLREOL
ENDIF
PAUSE 250 ' give slave time to reset
ENDIF
GOTO Build_Packet
TO_Error:
DEBUG CRSRXY, 8, 6
DEBUG "Timeout error", CLREOL
GOTO Build_Packet
END
' Subroutines
' Reset the IR Buddy. This code is useful for clearing data from the RX
' buffer and prepping to switch modes. Timing specific; do not change.
IR_Buddy_Reset:
LOW IRbSIO ' signal reset
PAUSE 5
INPUT IRbSIO ' release reset signal
PAUSE 50 ' allow time for reset actions
RETURN
Clear_Buffer:
FOR idx = 0 TO 7
buffer(idx) = 0
NEXT
RETURN
Make_CheckSum: ' checksum of bytes 0 to 6
chkSum = 0
FOR idx = 0 TO 6
chkSum = chkSum + buffer(idx)
NEXT
RETURN
Show_TX_Packet:
DEBUG CRSRXY, 4, 4, CLREOL ' clear last RX message
DEBUG CRSRXY, 4, 3, CLREOL ' clear last TX message
GOTO Show_Packet_Data
Show_RX_Packet:
Show_Packet_Data: ' display packet bytes
FOR idx = 0 TO 7
DEBUG HEX2 buffer(idx), " "
NEXT
RETURN
' File...... IRB Slave.BS2
' Started...
' {$STAMP BS2}
' {$PBASIC 2.5}
' This program waits on an eight-byte packet from a master controller. The
' packet is checked and, if valid, the command and data are acted upon. A
' corresponding eight-byte packet is returned to the master.
' Revision History
' I/O Definitions
LEDs VAR OUTA ' LED control outputs
' Constants
IRbBaud CON IRb96
STX CON $02
ACK CON $06
NAK CON $15
LedsOff CON $C1
' Variables
buffer VAR Byte ' rx-tx buffer (8 bytes)
cmd VAR Byte
data1 VAR Byte
data2 VAR Byte
data3 VAR Byte
data4 VAR Byte
data5 VAR Byte
chkSum VAR Byte
header VAR buffer ' rx packet
ackByte VAR buffer ' ack/nak byte
rxChkSum VAR Byte ' possible packet errors
' EEPROM Data
' Initialization
Setup:
LEDs = %0000 ' LEDs off
DIRA = %1111 ' make LED pins outputs
' Program Code
Main:
RX_Packet:
SERIN IRbSIO, IRbBaud, 2000, TO_Error, [noparse][[/noparse]STR buffer\8]
errorLevel = %0000
Check_RX_Packet:
IF (header = STX) THEN
errorLevel = errorLevel | ErrChkSum
ENDIF
ELSE
errorLevel = errorLevel | ErrHeader
ENDIF
Process_Command:
SELECT cmd
CASE LightLEDs
LEDs = data1 ' move data1 value to LEDs
CASE LedsOff
LEDs = %0000
CASE ELSE
errorLevel = errorLevel | ErrCommand
ENDSELECT
ENDIF
Make_Packet:
header = ACK
ELSE
header = NAK
data1 = errorLevel
ENDIF
GOSUB Make_CheckSum
TX_Packet:
TX_Wait:
GOTO Main
TO_Error:
' put code here that handles timeout error
GOTO Main ' reset, look for new packet
END
' Subroutines
IR_Buddy_Reset:
PAUSE 5
RETURN
chkSum = 0
FOR idx = 0 TO 6
NEXT
RETURN
I found out how to move the servos by simple subroutines. Now I need alot of help on send values such as 2658 to the slave. Any idea how to do this with the IR?
Thanks again
Sending a data packet is pretty well explained in the IR-Buddy's documentation.
