Resonator info
Robert@HCC
I have a IC that requires a 4Mhz resonator. I noticed that the schematic showed it hooked up the same way as a crystal (two outer pins). I just got the resonator today, and noticed it has three pins. Can someone tell me what the middle pin is for? First time ive used these, and just want that little detail clear in my head..
Alohas,
Robert
Alohas,
Robert
The middle pin should be connected to ground.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"I'm a man, but I can change, if I have to, I guess" The Red Green Show
Alohas,
Robert
Doesn't the middle pin ALSO mean that no additional capacitors are required [noparse][[/noparse]unlike the two pin version]?
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
·· Not necessarily.· You need to read the datasheet for a given resonator to know which size (if any) caps are installed inside.· Crystals obviously requite them separately, however these are also usually the most accurate clock source.
csavage@parallax.com
