Downloading troubles
I'm using a regular serial port on a new labtop. What COM number is that?? I tried COM1-5, and all but 3 is invalid port, but i can't download to 3 either? There's an echo but no loopback, so it doesn't find the BS2. What is wrong?? Is the BS2 just low on batteries? It is on when i download
·Somebody said...
-Never Underestimate the power of human stupidity.
Control Panel
· System
··· Hardware
····· Device Manager
······· Ports, Press the +
········· gives a list of available ports w/ COM #s
Post Edited (PJ Allen) : 7/13/2006 1:49:05 PM GMT
· If it was working yesterday, then sometime between then and now someone managed to knock the serial port off-line.
WHOA BOSS! Did you indicate "Stuffit" ? If so, "Stuffit" is a Mac utility. We're presuming you're operating a pure Microsoft Windows PC here, or at least I was! Is that the case?
Bruce Bates
<!--StartFragment -->
Post Edited (Bruce Bates) : 7/13/2006 7:30:49 PM GMT
Are you sure you're not confusing a DB-25 serial port on the back of your machine with a DB-25 PARALLEL PORT? The LPT (printer) port is a FEMALE connector. The SERIAL PORT(S) are MALE connectors.
The following may or may not apply to your own electrical educational experience. My apologies if it's superfluous.
As unusual as it may sound, I realize that·many folks don't quickly grasp the concept of MALE-FEMALE connectors. That observation comes from my 20 years of experience in the wholesale electrical industry. Neither of us should apologize for that lack of information.
A (so called) MALE connector has a pins or prongs which extend out from the body of the connector. Don't be fooled by male connecters which may have a shroud around them. If exposed pins are there, it's male!
A (so called) FEMALE connector _never_ has any exposed pins, it always has holes or receptacles into which the male pins find their "home".
If any of this sounds like a honeymoon, you're ON the right TRACK!
Bruce Bates
