serial comms expansion
Hi there,
I have a Boebot with a BS2. I would like to use the Boebot to do the following,
1. Use Boebot to obtain range readings with a Laser range finder sensor of my own.
the range finder has a RS232 interface.
2. Use the Boebot to relay the range data information out to another storage equipment.
This equipment also has a RS232 interface.
With the above requirements, it seems that on top of the RS232 port provided on the
Board of Education, i will need 2 more RS232 ports, one for Input and one for output of the
readings.
may i enquire if this is possible?
If so, would the BASIC Stamp 1 Serial Adapter help to provide the solution?
Thank you all for taking the time to read this post. i am an amateur so i beg your pardon
if my questions appear really elementary and silly.
Thanks again.
Haninator
readings.
Thanks again.
Haninator
So the Appmod says that it is "stackable" meaning, i can have 2 serial Appmods stacked to acheive the one for input and the other for output functionality right?
Thanks again!
haninator
Best regards,
Haninator
