tv_wtext question
Hi
I was trying out this code, and from some reason I cant get 40 chrs/col.
One row is always missing on the screen.
http://forums.parallax.com/showthread.php?p=590631
Here's my code:
'start
CON
· _clkmode····· = xtal1 + pll16x
· _xinfreq······· = 5_000_000
· basepin······· = 12
· CLS·········· · = $00· 'clear screen
· HOME········ · = $01· 'home
· CRSRXY······· = $02· 'set X, Y position (X, Y follow)
· CRSRLF······· ·= $03· 'cursor left
· CRSRRT······· = $04· 'cursor right
· CRSRUP······· = $05· 'cursor up
· CRSRDN······· = $06· 'cursor dn
· USECLR········ = $07· 'use color C (C follows)
· BS·············· ·= $08· 'backspace
· TAB············ ·= $09· 'tab (8 spaces per)
· LF·············· ·= $0A· 'linefeed
· CLREOL······ · = $0B· 'clear to end of line
· CLRDN········ · = $0C· 'clear down (to end of window)
· CR··············· = $0D· 'return
· CRSRX······· ·· = $0E· 'set X position (X follows)
· CRSRY······· ·· = $0F· 'set Y position (Y follows)
· DEFWIN····· ·· = $10· 'define window· W (W, Left, Top, nCols, nRows follow)
· USEWIN······ · = $11· 'use window W (W follows)
· DEFCLR······ ·· = $12· 'define color C (C, FG, BG follow)
· SCRLLF······ ·· = $13· 'scroll window left
· SCRLRT····· · · = $14· 'scroll window right
· SCRLUP······ ·· = $15· 'scroll window up
· SCRLDN····· ··· = $16· 'scroll window down
· CHGCLR······ ·· = $17· 'change all colors in window to C (C follows)
· CLRW········· ·· = $1E· 'same as CLR, but can be used in strings.
· ESC············ · = $1F· 'escape next character C (i.e. print as-is) (C follows)
· ZERO··········· · = $FF· 'can be used for 0, which is not allowed in strings, for command 'arguments
OBJ
· pr : "tv_wtext"
PUB start
··pr.start(basepin)
· pause(1)
· pr.out (CLS)
· pr.str(string(CHGCLR ,6))
· pr.str(string(CRSRXY, ZERO,ZERO,"1234567890123456789012345678901234567890"))···
· pr.str(string(CRSRXY, ZERO,1,"1234567890123456789012345678901234567890"))··
· pr.str(string(CRSRXY, ZERO,2,"1234567890123456789012345678901234567890"))
· pr.str(string(CRSRXY, ZERO,3,"1234567890123456789012345678901234567890"))
· pr.str(string(CRSRXY, ZERO,4,"1234567890123456789012345678901234567890"))···
· pr.str(string(CRSRXY, ZERO,5,"1234567890123456789012345678901234567890"))··
· pr.str(string(CRSRXY, ZERO,6,"1234567890123456789012345678901234567890"))
· pr.str(string(CRSRXY, ZERO,7,"1234567890123456789012345678901234567890"))
· pr.str(string(CRSRXY, ZERO,8,"1234567890123456789012345678901234567890"))···
· pr.str(string(CRSRXY, ZERO,9,"1234567890123456789012345678901234567890"))··
· pr.str(string(CRSRXY, ZERO,10,"1234567890123456789012345678901234567890"))
· pr.str(string(CRSRXY, ZERO,11,"1234567890123456789012345678901234567890"))··
' end
My second question is how to add keyboard function to this code to get fully functional
text editor?
PVJohn
Here's my code:
'start
CON
OBJ
· pr : "tv_wtext"
PUB start
··pr.start(basepin)
· pause(1)
· pr.out (CLS)
' end
text editor?
PVJohn
Yup, you're right. tv_wtext uses a delayed linefeed mechanism, so you can fill lines without causing an immediate scroll. Where tv_text might do a newline, tv_wtext just sets the eol flag, relying on a subsequent character to trigger the newline. But I failed to consider that CRSRXY should reset the eol flag. So you were getting an extra linefeed.
Attached is a new version to try. I've patched some other eol errors, too. Hopefully, I haven't created more in the process...
This looks fine now! Thanks. Can you halp me to add a keybord function to your code to make text editor? Sincerely,
PVJohn
'Glad it worked out! Please let me know if anything else crops up.
I'm pretty pressed for time these days (busy getting the PropCAM finished and kitting up more PropSTICKs). Plus I haven't done a thing with the keyboard yet. So I'm afraid I'll have to decline your editor invitation for now. Sorry...
I'm not sure what's happening, but when I run this code one character always goes to the next (6th) row, and then comes back to the 5th row, but then it it skip one column. Here's what I do:
CON
· _xinfreq····· = 5_000_000
· basepin······ = 12
· CLS·········· = $00· 'clear screen
· HOME········· = $01· 'home
· CRSRLF······· = $03· 'cursor left
· USECLR······· = $07· 'use color C (C follows)
· BS··········· = $08· 'backspace
· TAB·········· = $09· 'tab (8 spaces per)
· LF··········· = $0A· 'linefeed
· CLREOL······· = $0B· 'clear to end of line
· CLRDN········ = $0C· 'clear down (to end of window)
· CR··········· = $0D· 'return
· CRSRX········ = $0E· 'set X position (X follows)
· CRSRY········ = $0F· 'set Y position (Y follows)
· DEFWIN······· = $10· 'define window· W (W, Left, Top, nCols, nRows follow)
· USEWIN······· = $11· 'use window W (W follows)
· DEFCLR······· = $12· 'define color C (C, FG, BG follow)
· SCRLLF······· = $13· 'scroll window left
· SCRLRT······· = $14· 'scroll window right
· SCRLUP······· = $15· 'scroll window up
· SCRLDN······· = $16· 'scroll window down
· CHGCLR······· = $17· 'change all colors in window to C (C follows)
· CLRW········· = $1E· 'same as CLR, but can be used in strings.
· ESC·········· = $1F· 'escape next character C (i.e. print as-is) (C follows)
· ZERO········· = $FF· 'can be used for 0, which is not allowed in strings, for command arguments
· dpin· = 26·····················································
· cpin· = 27
· NewLine = 13
'· KeyLocks_Setup = %0_000_010··· 'CapsLock ON··········
· KeyLocks_Setup = %0_000_000··· 'CapsLock OFF
· AutoRepeat_Setup = %01_01000·· 'See number(3) at the bottom.
OBJ
· pr : "tv_wtext"
· KB : "Keyboard"
PUB start· | col, row, taster
·col := 1
·row := 1
· pr.start(basepin)
· pause(1)
· pr.out (CLS)
·· 'start keyboard
· KB.Startx(dpin, cpin, KeyLocks_Setup, AutoRepeat_Setup) 'IS· - Edited by Beau Schwabe (May 18, 2006)
· WaitCnt(50_000_000 + Cnt)
·· Repeat
····· taster := KB.GetKey
······ pr.str(string(CRSRY,5))
······ pr.out(taster)
BTW, CRSRx works fine.
My second question is how can I replace numbers and use variables for CRSRY, CRSRX and CRSRXY?
For example:
·· Repeat
······ pr.str(string(CRSRXY,col,row))
······ col=col+1
Thanks for your replay.
Sincerely,
PVJohn
Can you post an example of this behavior that doesn't use the keyboard?
To answer your second question, string does not allow embedded variables. You will have to use pr.out for col and again for row.
Phil
PVJohn
CON
· NewLine = 13
OBJ
· pr : "tv_wtext"
PUB start·
· pr.start(basepin)
· 'pause (1)
· pr.out (CLS)
· pause (2)·········
·· Repeat 45
······ pr.str(string(CRSRY,ZERO))
······ pr.out("A")
PRI pause(t)
· if t < 0
··· t := clkfreq / ||t
· else
··· t *= clkfreq
· waitcnt(t + cnt)
John
I tried your code, and it's doing what it's supposed to do. CRSRY just changes the Y position and leaves X where it was. If X was at the end-of-line, a newline is executed before the next character is printed. But this is probably not what most people want or expect. So I changed the code to check for the end-of-line condition upon a CRSRY. If the condition existed, then X is simply changed to 0 and the end-of-line condition reset. This prevents the newline from happening. (The revised tv_wtext object is attached.)
As to your other question, I won't edit your program for you, but I'll show you how to do it:
where col and row are variables.
Thanks very much for your time and help.
PVJohn
