Serial LCD to display pulserate
I want my 2x16 parallax serial lcd to display pulserate from the pulsin command (for debugging purposes ) but its not working...here is my program
pulse VAR Word
lcd PIN 14
lcdbaud CON 32
DO
PULSIN 15 , 1 , pulse
PAUSE 500
SEROUT lcd , lcdbaud , [noparse][[/noparse]pulse]
LOOP
any suggestions?
thanx in advance
There once was a lady named Bright
who traveled much faster than light
She departed one day in a relative way
and Returned on the Previous Night
Cheers,
Wannabe Ub3r Geek
pulse VAR Word
lcd PIN 14
lcdbaud CON 32
DO
PAUSE 500
LOOP
any suggestions?
thanx in advance
Cheers,
Wannabe Ub3r Geek
What baud rate were you planning to use, and which Stamp are you using?
Bruce Bates
<!--StartFragment -->
csavage@parallax.com
lcd PIN 14
lcdbaud CON 32···························'(Is this for 19,600 bps?)
DO
PULSIN 15, 1, pulse
PAUSE 500
pulse = pulse * 2
SEROUT lcd , lcdbaud , [noparse][[/noparse]DEC pulse, " usec"]
LOOP
I put in DEC (decimal equivalent), otherwise the LCD would·interpret the value for pulse as an ASCII character.
(CS and I must've been working on this at the same time.· I went to the parallax site to check on the serial lcd datasheet.)
Post Edited (PJ Allen) : 7/13/2006 3:52:38 AM GMT
32 is the constant for 19200 baud...
Cheers,
Wannabe Ub3r Geek
