Don't understand strings as parameters
John Abshier
CON
_clkmode = xtal1 + pll16x ' use crystal x 16
_xinfreq = 5_000_000 ' 5 MHz cyrstal (sys clock = 80 MHz)
LCD_PIN = 0 ' for Parallax 4x20 serial LCD on P0
LCD_BAUD = 19_200
LCD_LINES = 4
VAR
byte token[noparse][[/noparse]10]
byte head
byte tail
OBJ
lcd : "debug_lcd"
PUB main
if !lcd.start(LCD_PIN, LCD_BAUD, LCD_LINES) ' start lcd
abort
lcd.cls
head := 0
lcd.cursor(0) ' cursor off
lcd.backLight(true) ' backlight on (if available)
bytefill(@token,0,10)
lcd.str(string("test 2", 13))
GetToken(@teststring,@token)
lcd.str(string("returned from GetToken", 13))
lcd.str(@token)
pub GetToken(instring, tok) | curChar
tail := 0
lcd.str(string("in GetToken", 13))
lcd.putc(instring[noparse][[/noparse]0])
repeat
curChar := instring[noparse][[/noparse]head + tail]
if curChar == ","
quit
elseif curChar == "*"
quit
elseif curChar == $0
quit
tok[noparse][[/noparse]tail++] := curChar
head := ++tail
return
DAT
' teststring byte "$GPGGA,123519,4807.038,N,01131.000,E,1,08,0.9,545.4,M,46.9,M,,*47",0
teststring byte "$GPGGA,123519,4807.038,N,01131.000,E,1,08,,,,46.9,M,,*47",0
I am passing the address of teststring and token to GetToken.· But I don't understand how to address them as strings/array of bytes named instring and tok in GetToken.· GetToken never returns and the lcd.putc call writes nothing to the lcd.· I guess I could not use token a an argument to GetToken and use the global variable token, but I really would prefer to use it as an argument so other objects could call it.
pub GetToken(instring, tok) | curChar tail := 0 lcd.str(string("in GetToken", 13)) lcd.putc(byte[noparse][[/noparse]instring][noparse][[/noparse]0]) <---------------- repeat curChar := byte[noparse][[/noparse]instring][noparse][[/noparse]head + tail] <---------------- if curChar == "," quit elseif curChar == "*" quit elseif curChar == $0 quit byte[noparse][[/noparse]tok][noparse][[/noparse]tail++] := curChar <---------------- head := ++tail returnCharlie
