Serial data between BS2's — Parallax Forums
ee95816ee95816 Posts: 1
edited 2006-07-12 22:24 in BASIC Stamp
I am pretty new at using these things, and so far things have worked out as expected.··But I am having trouble sending·a single character from one BS2 to another serially.· I am using·SEROUT to send the data and SERIN to receive the data.· All I get on the reciveing end is gibberish.· The code looks to be fairly simple based on the help files, but I am getting nowhere.· Below is my code, can anybody alleviate my ignorance?
thanks in advance
Sending Unit
' {$STAMP BS2}
' {$PBASIC 2.5}
· SEROUT 1, 16780, [noparse][[/noparse]"H"]
Reciveing Unit
' {$STAMP BS2}
' {$PBASIC 2.5}
sData VAR Byte
SERIN 1, 16780, [noparse][[/noparse]sData]
DEBUG DEC sData
    edited 2006-07-12 22:12
    Look up SERIN or SEROUT in PBASIC Help.··Toward the end of those entries is a recommended set-up for Stamp-to-Stamp comms.
    If you want to see an H in DEBUG, then that line should be:
    DEBUG sData
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2006-07-12 22:19
    Even beyond what PJ said, you may have a synchronicity problem. Try the following in the receiving Stamp:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    sData VAR Byte
    sData = $FF
    Retry:
    If sData = $FF THEN Retry
    DEBUG sData
    END
    Bruce Bates
    <!--StartFragment -->
  • steve_bsteve_b Posts: 1,563
    have you connected a common ground between the 2 stamps?
    The tx line from one stamp has to go to the rx line of the other!
    Steve
